Bobalu
Some time ago I damaged the black plastic coupling that goes into the short upper barrel of the Jr. Gent II. Failing to obtain a replacement through the kit supplier, I have been looking for another kit that uses the same coupling, but would be cheaper to cannibalize. My research shows the Panache uses the same tube size and the coupling appears to be the same in the instruction sheet illustrations. Is there anyone that has both kits and can do a side-to-side comparison of each to confirm this?
