Rifleman1776
On another thread, the question was asked why some nibs fit cleanly onto cartridges set up for pens and why some did not. Of course, some kits might vary. But another consideration could be the size [diameter] of the cartridge mouth. Since I reload ammunition, I have access to fired and reloaded ammunition. My recent pen is from a 30-06. But, for those not familiar with firearms and ammunition, it should be understood that both 30-06 and .308 ammo (FOR OUR PURPOSES) are identical except for length. I measured the outside diameter [OD] of five fired cases and five resized and reloaded cases. Measurements were consistent for all. The fired cases measured .341" OD. The resized/reloaded cases measured .333" OD. I do not have any brand new cartridges on hand but they could be expected to measure smaller than the .333. I also measured the largest portion of a nib/writing tip from a 7mm European pen bought from CS. It measured .354". The instruction sheet from CS says the correct bushing for this fitting is .359". The pen I just assembled does have a tiny, nearly imperceptible, difference between the nib and casing. That would, according to these measurements be a difference of .013". Folks, I ain't sweating it.
