CA issue
avbill
San Bruno, CA, USA.
I have a pen where the Rhodium fitting sides inside the brass tubing. I remember several of you stating the CA emits gases as it cures. changing the finish. I asking any of you what adhesive would you use to prevent the component from siding? Would a drop or two of CA on the component really change the Rhodium finish?
epoxy ? or ....
dennisg
Jacksonville, Florida, USA.
I've used both ca and epoxy, leave the cap off the pen for 24 hours when using ca. I use lock tite more than the others lately. I think you will have to choose one depending on how loose the fit. No mather which you use, put it in the tube bot on the part.
Jim Burr
Banned
Reno, Nv
A drop of Med of Thick shouldn't hurt. The off gassing of CA is primarily to the exothermic reaction that's going to occur regardless. Remember that when you use it as a finish, there is a lot being used as opposed to the single drop for a part attachment.
Dave Turner
Sylvania, Ohio
I agree with Dennis. I always use a little Loctite Blue on every pressure fitted connection for insurance. If your fit is very loose, I would consider using a small amount of 5 minute epoxy, being careful not to get any on a visible surface.
