3/8" to V
jennera
Texas
Are there any tips or tricks to getting a 3/8" tube to fit on a V kit?
The circuit board blanks are 3/8" and will not fit the bushings for the V kit. We tried boring the tube with a V size reamer but the tube heated up and came out then the blank cracked.
Thanks!
Sent from my SAMSUNG-SM-G890A using Tapatalk
magpens
Canada
Gee ! . I would never expect that to happen because you are reaming so little material off, like a hair's thickness (0.002" or less)
Were you turning the reamer by hand or by machine ?
I always ream by hand, but forgot to mention that in previous discussion.
EDIT: . Just occurred to me to say that the V-size applies to the fitting of the outside of the tube to the blank; not to fitting the bushings to the inside of the tube.
If you do a V-size ream on the inside of the tube that is way too big, sorry to say; and you will remove, perhaps, all of the brass tube
https://hypertextbook.com/facts/1999/BrianLey.shtml
jennera
Texas
Yes that's what happened; the tubes came out. I'm trying your advice with a dowel and sandpaper now. I am surprised the bushings are so large so I'm also checking measurements on them in case I ordered the wrong ones. The label on the bag was correct but they are are too large for the 3/8' tube. I checked the measurement on the tube and it is a 3/8".
Jennifer
ed4copies
Local Chapter Manager
Racine, WI, USA.
MAKE BUSHINGS THAT FIT!!!!!
Use corian or a resin blank and glue a 7mm tube in it, then turn to fit the inside diameter of your tube. Simple and ACCURATE!!
Here's the vid, that shows how, but I am not sure this answers your real question --regarding using the circuit board blank.
https://www.youtube.com/watch?v=znNBgzhl_pM
jennera
Texas
Ed, I ordered the 35A bushings that go with the kit and the bushings we received are labeled 35A. I checked the measurements on the IAP bushing tube chart which says the inside part of the tube should be .345" (E & K) but when I measure it, it reads .35". The other measurements appear to be a bit off also.
Do you think I should order and try another set of bushings? Would that small of a difference cause the issue?
I did question the goblin to make sure she didn't mix her bushings up out in the garage. I haven't inspected her work area myself (yet) but she claims she has no other bushings that are black like these.
Thanks!
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Thanks!
It does sound like a possible bushing mixup somewhere - what do you measure on the other end of that bushing?
One of the Breast Cancer Awareness bushings is .350/.366 but neither end goes into a tube. Both ends of that one butt up against a 7mm tube. There are also other .350 bushings that aren't intended to fit into a tube as well.
