B&W Waves on a Jr Retro
See more from skiprat
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
This little closed ended Retro is fresh off the buffing wheel. Has wave segments with brass shim borders. The shim is slightly thicker than I normally use or like, but my local K&N Metals stockist was closed this morning. :mad::rolleyes: I was concerned that the shim would feel proud of the resin once sanded and polished, but it turned out not so bad afterall. :rolleyes:
I hope you like it. Any comments, critiques, questions welcome.:wink:
I do have 'in progress' pics but they have a fingerprint on my cameral lens:redface:. But I'll show them if someone want to know how it was made.
Beautiful!!!
I think I know how you did it but wouldn't mind a peek at the wip pics to confirm. Hollows and rounds (arcs and coves) nested together?
Pretty slick there Skip. I like the thicker shims, in fact they could have been a touch thicker and it would have been fine looking.
Here are the WIP pics. Again, apologies for the smudge.:redface:
Max, I use CA for EVERYTHING. :biggrin: I know lots of folks have problems when drilling through metal and it heating up and wrecking the joint, but now that we know the problem, it's simple to overcome. I drilled this with a 4mm pilot first then used about 7 different sizes to get to the final size.
All of the drill bits were freshly sharpened and I used soapy water as well.
I drill on the lathe at around 600rpm. I would go faster but never slower than that.
The only 'trick' with this design is that the segments including the shim must have the exact same diameter as the cutter. :wink:
Hi Steven, Fabulous pen! the segmenting is flawless. Thank you so much for showing WIP pics, I would have never figured it out how you achieved that segmenting. Now all I need is a metalworking lathe...
Eric...
Skip thanks for sharing your work. That whole setup is impressive and rather mind boggling. Without the visual I would never have gotten a grasp. My left brain works, but my right brain is slow in catching up. Looks like both sides of your brain work pretty darn good!! : ) Thanks again for the pics
Sent from my iPad using Forum Runner
Eric, the lathe was used to hold the router only. :wink: ( and drill the holes of course.
Granted, a metal lathe helps but a half decent MDF jig and a router table would do the same. :biggrin:
This pen is incredible. I am so glad you're back posting these. It gives me something to shoot for, and dream about!
Oh, and personally, I don't think these shims are too thick. At this thickness, it looks like they are an integral part of the design, instead of merely being used to separate the various pieces. A very impressive design.
I drill on the lathe at around 600rpm. I would go faster but never slower than that. . :wink:
Thanks Skip for the info, I have tried 3 steps but not 7. Next time I will increase my drilling steps and include a soapy water spray bottle. :smile:
Steve, such a stunning job as always! I never would have thought of using a router in that way to make waves, now more of your other work makes more sense on how you create such unique designs! Very well done chap!
And that is what I have and may have to give this a try. Thanks for showing.
Looks like Skips Ying Yang pen.
My wife who seldom has a good thing to say about most of the pens I show her, just walked by, stopped and turned around, and exclaimed..."That is Gorgeous!!!" I totally agree with her. That is a beautiful pen and very nice work. Good Job!
Rick (mtgrizzly52)
