1st stamp pen
See more from rich gubbin
rich gubbin
leicestershire UK
Hi there,
Following on from my thread about making these stamp blanks, I finally turned it today. This one is the second attempt as the first one (test piece) chipped out to bad on the ends. I went a little easier on the next one and here,s the result. I have just poured 2 more with more interesting and colorful stamps on. C&C welcome please.
Rich
SDB777
Cabot, Arkansas USA
Stamps are fun, been doing them for some time now. Still learn something new with every stamp tried(mostly which will shrink and which won't)....
Here's a tip....after you square the ends, apply some thin CA to keep water from getting between the stamp and the PR(for everyone else looking, I think you must know already-cause I don't see any 'clouding' on yours).
Colorful, fun, and interesting....all at the same time!!
Scott (could it be mailed now) B
rich gubbin
leicestershire UK
Hi All,
I poured my second lot of stamp blanks today, this time the tubes were painted black (acrylic) not good. The black seeped through and discolored the stamps. This seem odd as i had sealed the stamps like the first castings. Any thoughts or input greatly appreciated.
Janster
Nevada
....:biggrin:.take this for what it's worth as I have ZERO experience doing what you did. I suspect one could CA over the paint BEFORE applying the stamps and then your clear casting. I believe that would stop any seepage, and don't foget the ends of the tube. Money will be refuned if this does not work!
RSidetrack
Fayetteville, PA
....:biggrin:.take this for what its worth as I have ZERO experience doing what you did. I suspect one could CA over the paint BEFORE applying the stamps and then your clear casting. I believe that would stop any seepage, and don't foget the ends of the tube. Money will be refuned if this does not work!
+1 - I ca over painted tubes for my label pens because of seepage. While you may coat in acrylic- something about the paint reacts. The CA works great and be sure to give it time to degas
