patmurris
Hi all!
This is my very first casting experiment, and i went with... plaster. I wanted to try that for a while so i finally built a one blank mold and casted a plain plaster blank:
I was afraid it would break apart any time but it went rather well at all steps. Plaster is rather smooth and easy to 'grind'. I started turning with my regular tools which went well, but switched to coarse grain sanding at some point and finished it that way to save the tools. It was probably a good idea since there were sand particles here and there which did wreck the sanding paper.
No finish to speak of. Sanded (grinded) with 40 grit, did a couple pass along the axes and that's it. Call it construction rough. The center band is 5mm (about 3/16") plywood of course... :biggrin:
This pen is not close to be usable though. Plaster is very brittle and it would not survive a trip in a bag and even less a fall from a desktop. I would not recommend anybody to carry it in it's breath pocket... unless they are wearing work cloth, but then it would better be in concrete! - which i'm thinking of trying too.
Anyway, it did work out and i'll certainly cast more plaster blanks, including some sort of pigments this time.
