Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Reply
Thread Tools Display Modes
Old 01-18-2010, 09:46 AM   #1
rayzir
Photos: 0
Default Noob Startup Equipment
I'm looking to get into the hobby (as if I need another one...LOL), and I've been saving my pennies. I almost have enough for to buy my first lathe. I'm looking at the JET JML 1014VSI. But just having a lathe won't let me turn. I need the addons. Namely chisels, pen turning starter kit, and sharpening gear. Unfortunately, the lathe will pretty much deplete my funds.
I'm looking at a Pen Turner's Starter Kit from WoodTurnersCatalog. Are these starter kits a good way to get the much needed supplies/tools? Or is there a better way to stretch my dollar? Should I piece-meal it?
As for sharpening, by the time I invest in an 8" grinder and the jigs, I'm looking at $250-300. Is there a down and dirty way of sharpening without the grinder until I can scratch together more funds? Is hand sharpening an option? How often do you have to sharpen your tools? Is it feasible to use a local sharpening service? Or will I be there every 20 minutes?
Basically, I need to know what I need to get by. I can add equipment over the next few months to round out my arsenal.
Thanks for the advice, y'all.
rayzir is offline   Reply With Quote Top
Old 01-18-2010, 09:51 AM   #2
glycerine
Photos: 29
Default
do you have a belt sander? Some people also sharpen on sanders. Also, once my tools started wearing down, I started taking more material off of my blanks with my sander as well so that I would spend less time dulling my tools on the lathe. Sort of takes away the fun of turning, but it's just something I had to do since I didn't have any way to sharpen. I am working on making a jig right now and actually bought a grinder as well so I wouldn't have to use my sander...
As far as the starter kits, I can't say, but I DO have a used Turncrafter Pro and I think it's great!
glycerine is offline   Reply With Quote Top
Old 01-18-2010, 10:28 AM   #3
JimB
JimB's Avatar
Photos: 0
Default
I have the same lathe as do many others on here. As for chisels, I didn't have much to spend when I started so I bought the set from Harbor Freight for less than $50. It has 8 tools and I still use them all. You don't need to spend that much on sharpening either. I have a $25 6" grinder and made my own sharpening jig from scrap wood like many on here do.
As for the starter set, I think you will get mixed responses. I never bought one as it seemed they had some good things in them but some of the things I didn't want or need.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 01-18-2010, 10:32 AM   #4
Lenny
Lenny's Avatar
Photos: 26
Default
This is what I did ... (the starter set) http://www.woodturnerscatalog.com/st...tials_kit?Args=
It has everything to get you started less the chisels.
You might want to consider Turning Between Centers rather than using a mandrel.(search this site for some excellent tutorials)
A gouge, a Skew, and a parting tool are all you would need to start out. I think 3/4" or 1" are better choices than the smaller ones. If you want an inexpensive SET of high speed steel look at these...
http://www.harborfreight.com/cpi/cta...emnumber=47066
Or look on ebay for individual chisels (about $25-30 each)
As for sharpening... yes you can spend $$$! and maybe you will want to at some point... but you can also buy an inexpensive 6" grinder on the cheap that will get you going. Sharp tools are a must... learning to sharpen them properly is just that .. a learning proccess! (Eventually)Get one good aluminum oxide wheel and check out the thread about homemade grinding jigs.
Don't forget to check craigslist as well. you can often find some good deals.
You are one the edge of a slippery slope! We are here with a hand at your back to guide you.... (or push you over the edge)
Lenny is offline   Reply With Quote Top
Old 01-18-2010, 11:37 AM   #5
Sberger
Photos: 0
Default
Just be sure that you get HSS(High Speed Steel, I think) for your tools. You only need about 5 basic tools. Grinders can be found for about $25 for sharpening. Watch a sharpening video. Woodsmith has a good video on sharpening. Safety glasses, a few shop supplies and you are off. Get some cheap Slimlines and give it a try. I have a Turncrafter VS and it is fine. You will also need a mandrel.
Steve
Sberger is offline   Reply With Quote Top
Old 01-18-2010, 11:46 AM   #6
RussFairfield
Photos: 0
Default
Here is how I did it.
http://www.woodturner-russ.com/Pen10.html
Others may disagree.
__________________
Russ Fairfield
Post Falls, Idaho
Visit my Website for instructions on making a pen
RussFairfield is offline   Reply With Quote Top
Old 01-18-2010, 02:26 PM   #7
broitblat
broitblat's Avatar
Photos: 281
Default
If you're just doing pens, I think you can get away with only a spindle gouge and a skew - but get those in a good quality high speed steel. Then, if those are the tools you are using, you should be able to have good success sharpening on a sander or a low cost wet sharpening (I started on a delta that ran about $40, I think)
-Barry
__________________
Nice play! (well, it's not exactly work, is it?)
Barry Roitblat
Bellevue, WA
http://thepenmall.com
http://adifferentturn.1000markets.com
broitblat is offline   Reply With Quote Top
Old 01-18-2010, 02:38 PM   #8
parnelli_97
Photos: 0
Default
I bough a carbide tool set. They have not needed sharpening since I bought them in August. They are still near razor sharp. My HSS tools have needed sharpening every 7th or 8th turning. Less If you do acrylic or hard wood. Also I do not have a grinder, I use a normal sharpening stone then I switch to 600 grit sandpaper and the tool ends up razor sharp with a mirror like finish. So as far as a grinder, save your pennies and buy a cheap diamond stone at Harbor Freight. Then watch Criagslist for a used grinder.
Here's a link to the carbide tools. I love these.
http://www.pennstateind.com/store/LCPM3CAR.html
And my HSS tools are old Craftsman set I got from Craigslist. They are built like a Sherman tank. I have yet to find a mid level HSS set that are as thick and sturdy as these. (a little secret a lot of people buy those cheapo Harbor Freight lathes and a decent set of tools. I bought the cheap lathe on craigslist with the tools for $60, kept the tools and re-sold the lathe, the next day, for $60)
parnelli_97 is offline   Reply With Quote Top
Old 01-19-2010, 12:35 AM   #9
Boodrow
Photos: 0
Default
I've got the little variable speed drive lathe from Harbor Freight $120, the HSS tools from HF $10, the HF 8" Drill Press $60, and bought my 1MT Adjustable Pen Mandrel from Wood Crafter I think $20. The only thing that I've had to replace so far is the Live Center. I wasn't real sure if I would really get into turning pens or not so I didn't want to drop a fortune before I was sure. Turns out I'm pretty much addicted, I can get a project done in about 30 minutes which works out well with my ADD....LOL. I'm looking at up grading my lathe now but I plan to use the Little HF Lathe as a dedicated buffing and finishing tool. Just my two cents, good luck and have fun!!!
Boodrow is offline   Reply With Quote Top
Old 01-19-2010, 06:40 AM   #10
workinforwood
workinforwood's Avatar
Photos: 31
Default
The lathe choice is a good one. Pen starter kit...waste of money in my opinion.
Purchase Lathe
Then...
Dead center 60
Live center 60
3/4 gouge
CA glue or finish of your choice
Dial calipers
Decide what pen are you going to make?
Lets say it's a slim...
7mm drill bit, and 7mm barrel trimmer
(2) slim bushings from Johnny CNC
Done.
Now you want to make some cigars?
10mm drill bit
10mm barrel trimmer
Cigar bushings from Johnny CNC
Done
Keep it simple, spend your money once. No need for a mandrel that you will have to replace and the factory bushings are cheap and wear out fast. You just drill the blank. Glue in the tube. Barrel trim it. Install Johnny bushings in each end. Stick it on the lathe between the 60 degree centers and turn down to size. Then start do the next barrel same way.
__________________
Jeff Powell, Master Scroller
www.masterscroller.com
workinforwood is offline   Reply With Quote Top
Reply
Bookmarks
Tags
noob, starter, tools
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2010 Penturners.org, LLC
