For the Beginner, What do I need?
leehljp
Member Liaison
Tunica, Mississippi,
IF you have suggestions for adding to this, please post it below. On another forum, a lady asked what to do to get started in pen turning. I came up with only the simple basics as listed the below. It is not definitive but a beginning and an overview of the "big picture". Your input would be helpful also.
Beginners - Getting started: "What Do I need to get started?" A common question. Beyond that, many other questions come up. Below is a summary of each topic. Each boldface topic could have whole pages dedicated to it, but again, this is an overview to help you get familiar and get started. I hope this helps to answer a few questions and point you in the right direction.
I. LATHES, CHISELS and SHARPENERS:
Most any size lathe will do, but beware of a few "mini" pen lathes. Midi lathes are OK. "Mini" can get the job done but most people who have them don't like them. One exception is the Taig group of "mini" but it requires its own special set of tools.
PURCHASING A LATHE suggestions:
1. Look for a lathe with MT2 shanks. (MT2=Morse Taper #2) These have the most common accessories for pen turning and common bowl turnings.
2. Electronic Variable Speed or non-VS. To some this doesn't matter. To others who love to vary the speed for turning, fast for turning down, slow for sanding or applying finish, - VS is a real time saver. You can change the belt on the pulleys but this is an inconvenience to some. To others, the cost difference is not worth it. Beware that if you invest $200 - $350 for a lathe, it is doubtful that you will spend $400+ a year later for a new lathe just to get VS. Get the right one the first time.
Chisels - A divide here:
• Cheap lathe sets from Harbor Freight or other cheap tool shop - Some people recommend starting with cheaper tools to see if you like turning. Some people use these tools continually without the need for the more expensive tools.
• Get HSS (quality) tools from the beginning - nothing makes good turning like having good tools that you can depend on to hold an edge!
Your choice.
Skews, Scrapers and Gauges. A suggestion is to look for someone near you to help you get started - if you are a little afraid to learn on your own. There are online videos that are helpful too, just ask. In pen turning, the most popular two chisels are the Skew and Scraper. Scrapers seem to be easier for the beginner but the skew seems to allows finer control for most who use both proficiently. Lately there has been a few custom made chisels "called skogger" (on this forum) that uses small replaceable carbide blades. This acts more like a scraper and stays sharp longer. AND some argue that the nature of Carbide prevents it from being sharpened as fine as HSS or even normal steel.
Your choice.
Sharpeners come in many forms:
•Diamond hones;
•Fine Pressure Sensitive Adhesive sandpaper up to 2000 grit and more on a flat piece of glass for sharpening the tools;
•Specialty grinders and tool holding jigs;
Many choices and some of these sharpening devices are more expensive than some of the lathes used in turning pens.
A RAZOR SHARP tool is a necessity, and keeping the tools that way is prudent.
II. OTHER TOOLS - DRILL PRESS, PEN MILL, PEN VISE, PEN PRESS, PUNCH SET, CALIPERS and OTHERS:
• 1. A pen mill or sander is needed to make sure the pen blank and tube are square before adding the bushings and also assembling the pen. Some use a special jig to square up the ends on a disk sander, but it is necessary that the glued up blank is SQUARE for turning and assembly.
• 2. Pen vise is necessary to hold the blank to drill an aligned hole into the blank. IF you don't use a vise, you will find that blanks will have off centered holes and you will also find that some blanks will burst/blow out! The clamping force of the pen vise will help prevent blowouts but not all.
• 3. Pen press is a tool that presses the pens together. Some use the Drill Press, some make their own and some buy pen presses.
• 4. Disassembly Tools / Punch Sets. Harbor Freight makes a good punch set that is used for disassembly of pens when they need to be disassembled. This does happen on occasion. Helpful also for when the transmission assembly is installed too far. PSI and others have disassembly tools also.
• 5. Calipers: Many people learn from the beginning to measure the size of the turned blank with calipers. While it is OK turn to size based on the bushing, beware that the bushings will wear down and you will have to "guess" the size - so it is good to learn to use the calipers to measure size than the bushings themselves.
Caliper HOW TO: The Nib end (where the ball point comes out) the center band and the clip end - measure each with a calipers, mark them down on a piece of paper and then turn the blank to that size and apply finish.
Caliper Why: Many people turn the blank down to the bushings for size and often hit the bushing with the chisel. Dulls the chisel a little, - and in making 20 pens or so, the size of the bushing will be reduced by .01 inch, at least. BUT if you determine the size by using calipers, it doesn't matter what happens to the bushings. Also, as you sand the blank down to final size, you WILL sand the bushings a little and eventually the bushings will be .01 or .02 inch smaller than the nib, center band and clip end and it WILL be noticeable.
MOST people consider bushings as "consumables" and the average is 1 set of bushings per 20 to 40 pens. BUT, if you use calipers, you can extend the use of bushings even longer. AND if you use "mandrel-less/turning between centers" and remove the bushings for "finishing" the bushings will last a lifetime.
• 6. Other tools and items:
• Small diameter wire brush or rat tail file for cleaning glue out of tubes.
Insertion tool for inserting the glued tube into the glued blank.
Face Mask and Face shield, - Your health and safety is everything! Dusk Collector Optional but helpful. IF using a DC system, consider ear protection.
Rubber or other gloves to keep glue off of hands.
• 7.DRILL PRESS - the most used big tool after the lathe! Almost a necessity! 2 1/2 inch quill travel would be minimum. If purchasing a DP, then a 3 inch plus travel would be very beneficial. (Almost left this tool out of this.)
ADDITIONAL TOOLS for Expanding the creative pen base:
Table Saws and Band Saws help in cutting blanks, squaring blanks, and segmenting. Expands the creativity!
Pressure Pot: For stabilizing soft woods and corn cob type of blanks; For casting your own blanks with Resins, pressure keeps bubbles down.
(Vacuum and pressure are used for stabilizing. Pressure is used for casting resin.)
III. FINISHES:
First of all, don't just purchase Store finish items just because they advertise them well and sell them! Wax finishes don't finish. Wax wipes off or wears off in a week or so. Some people like a natural finished pen and the feel of the wood, but the pens get dirty in a few months like the edges of well used kitchen cabinets near the handles. If you like the natural feel of wood and a waxed finish (or of your customer does) be sure to be aware that it requires special care to keep it clean.
There are several great ways to finish pens and each has its advantages and drawbacks.
CA (cyanoacrylate/super glue) and BLO:
Advantages - quick finish, strongest, most durable, HIGH shine; Hardens soft woods (often referred to as stabilizing), protects well. It is generally the most requested finish by the vast majority of those who sell to the public. CA is often applied with paper towel as are some of the other finishes. It is also applied in different forms for different people with Boiled Linseed Oil (Called BLO for short).
Disadvantages: For some, it has a high learning curve; the fumes burn eyes, Sticks to fingers, Burns fingers; A few turners view it as "plasticky" looking; Some people are HIGHLY allergic or become allergic after a time - causes severe flu like symptoms.
Lacquer (Deft) and others: Advantage - Less plasticky looking and more natural.
Disadvantage: takes 2 hours to set and 12 - 48 hours to cure for final sanding.
Polyurethane (hard floor type) Similar to Lacquer. On medium and dark woods gives a good sheen and warm feel.
Disadvantage: tend to yellow white/holly (one of my favorites); 2 to 4 hours to set, 24 to 48 to finish to a fine sheen or shine.
Acrylic and acetone: Plexiglass strips placed in a glass jar filled with acetone will dissolve. Some people use this instead of CA. Less smell and fumes, less burning of the eyes, less allergenic. Similar properties to CA in finishing. Quick setup quick finish. High shine.
Disadvantage: high learning curve for application; must make your own; Some turners say it looks plasticky.
People with considerable experience in making, finishing and selling pens will tell you that "people and pens" are MUCH harder on "finishes" than the finish of fine furniture or floors or walls. Sweaty palms and humid shirt pockets are very caustic to finishes, plus the heat in a closed car in the summer or cold winter, along with humidity changes - play more havoc on pen finishes than finishes in an ordinary house. Finishes will degrade faster on pens as a result. Therefore, the most durable of paints and finishes are recommended. Use waxes over the finishes above but not under them.
• Sandpaper and polishes: Many kinds of sandpaper. One thing is clear, quality sandpaper is a necessity for those that turn a lot. There are debates on whether to sand beyond 400 or 600 grit and that is up to you. Some sand up to 1000 and beyond to bring the blank to final size and prepare it for accepting the finish.
One VERY popular product called "MicroMesh" can be purchased in sets that can be used many times and washed and used again. Some people use automotive rubbing compounds to polish the finish.
IV. PENS: Most people start with "Slimlines" because they are the cheapest. However, some consider the slimlines harder to make than other pens because of the smaller diameter and tubes. One piece pens are easy to start with such as Sierras, Aeros, Carbara, Elegant beauties. Be sure to order bushings for each model.
Cigars are popular pens that many people move up to after slimlines, because they are moderately priced and offer a more advanced look over slimlines. Beware that the cigar has 4 separate bushings and they have to be done in the right order. Still, the cigar is a great pen and easy to make as long as you make VERY sure the bushings are in the right order. I am sure that others would recommend a different pen to start or use as the second pen turing stage. If you decide you want to try another, go for it.
BUSHINGS and tubes: When you purchase pen kits, be sure to order a set of bushings for each KIND of pen you wish to make. ALWAYS order at least one set of extra tubes for each kind of pen you order. Two sets are better and tubes are cheap, so it helps to have a set on hand.
GLUEING THE TUBES: Most people use super glue (CA) to glue the tubes in. IF you go this route, use Thick CA as it allows a few seconds before setting up and allows more time to insert the tube BEFORE it sticks.
Some people use Gorilla Glue but it is very messy. Must allow overnight to use. Still it is a good glue and there are advantages in that it expands and does not allow air spaces between the tube and blank - a big contributor to blowouts.
Epoxy: Use 5 minute Expoxy if doing one or two pens/ Use 30 minute epoxy if you are gluing up 4 or more pens blanks at once.
-> HINT: Find some old playdough or find some plumber's putty. Stop up one end of the tubes so that glue does not get inside the tube. Insert the puttied end into the blank. Hardened Glue inside the tube can cause big problems during assembly.
Pen BLANKS:
Too many to mention here but will note that one common question from beginners: "What is a 'Stabilized Blank'?" Stabilized blanks are blanks of wood or other natural material that have been soaked in, or pressurized with a plasticized material to make it harder so that it turns without falling apart. One other common question is "What is BOW"? BOW is Bethlehem Olive Wood.
MANDRELS - TWO Sizes "A" and "B":
"A" is for 7mm pen kits and the most common.
"B" is larger in diameter was made because of the "flex" that was somewhat common in "A" mandrels, which in turn caused wobbles and Out Of Round (OOR) turned blanks.
• A THIRD VARIABLE: Adjustable mandrels. The length of the mandrels have some bearing on the flex that happens and also longer ones increase the possibility of the mandrel becoming bent. Adjustable mandrels allow for the length to be exactly as needed. Some people use this to eliminate the wobbles and flexing that comes with longer mandrels. Short mandrels mean turning one blank at a time. Longer mandrels allow you to turn both blanks at the same time, which often comes at the price of OOR. Flexing is not generally a problem with "B" mandrels.
• A FOURTH - an Alternative: Mandrel-less (Turning Between Centers) which will be noted later.
LIVE CENTERS: IF YOU USE A MANDREL, you will need a 60° live center: Most wood working lathes come with a "live center" on the tail stock for use on wood. "Mandrels" are metal, not wood. Therefore the little dimples in the end of the mandrel require a tail stock point that fits it - called a 60° (60 degree) live center - which are more common on metal turning lathes. If you don't use a 60 degree live center on the mandrel, you will very quickly find that the pen blanks are out of round on the tail stock end. You need a 60° live center to use with a mandrel.
DEAD DRIVE CENTER Use a "Dead Drive Center" if you are going "Mandrel-less", a.k.a "No-Mandrel", a.k.a. "Turning Between Centers". A dead drive is the opposite of Live Center. Dead Drive Centers are used in the head stock; Live Centers are used in the Tail Stock. Live Centers have a bearing in them and allow free spinning of the point that touches the turning blank or mandrel. Dead drives are just solid pieces of steel that fit the MT shank/spindle of the head stock of the lathe. (I know, redundant explanations but often necessary for beginners.)
Mandrels? Or go Mandrel-less? - Another topic for another post! Too much for here.
One of the problems in turning pens is that pens often come out OOR - "out of round" and the majority of the reasons for this is associated with a mandrel. For this reason, Many people are forgoing (eliminating) the mandrel for turning pens. It is referred to as Mandrel-less, No Mandrel or Turning Between Centers.
Please do a search for "Mandrel-less" for more details on this.
IF you have suggestions for adding to this, please post it below. On another forum, a lady asked what to do to get started. I came up with the basics of the below. It is not definitive but a beginning. Your input would be helpful also.
• Get HSS (quality) tools from the beginning - nothing makes good turning like having good tools that you can depend on to hold an edge! Your choice.
Hank; I usually recommend inexpensive tools to start. If you "mess up" sharpening a cheap tool, you don't loose a lot. I have purchased $10 PSI slews just to experiment with on different grinds. Get good tools when you can sharpen them properly to a scary sharp edge.
I believe a FAQ would be an excellent idea.
A Glossary and Acronym listing would be good too!
Is there any way to create a document that many people can update??
"Many hands make light work" ---- Amish proverb
Can't tell how many times have I seen each of the above listed in parts. It is good to get an overview together. And I do realize that all of that is just the beginning, but it brings the overall/big picture into focus for the curious beginner. Even for someone with flatwork background with a collection of tools, or even a turner coming to pens, it gives the big picture from which the details can be figured out.
Yep, I did leave out the money! :biggrin:
As an alternative to a drill press and good pen blank vise, you could substitute a good scroll chuck with Pin jaws ans a jacobs chuck to fit in the tailstock to drill pen blanks.
It may not be as useful if you are planning on doing some flatwork, but if pens/turning is pretty much all you would be doing, it might save you some money initially and the chucks can be used for many other turnings as well.
I am not such an expert (yet, but hopefuly...) to add anything, just wanted to say that having this kind of list about 16 month ago when I was starting with penturning, would be very great. This list should go to the library by my opinion.
Perhaps some starters might also find some DVD on total penmaking of its use. Russ Fairfield's DVD worked great for me.
Great work, Hank.
Hank,
Your post is priceless - I wish I had had this when I first started turning pens... I had tons of questions but no place to find out the answers in the beginning. I found out, as I am sure many of you old-timers, that without the basics firmly understood, it was a very lonely and dark road getting past the mistakes of the uninitiated pen turner. I luckily stumbled on this website/forum.
I still haven't tried mandrel-less turning but it's on my list of things to do in 2009.
One of my real issues in pen-turning is learning what is the proper way to sharpen my lathe tools. I have read articles that say for wood lathe turning you do not need a razor sharp tool while others say it is imperative for turning pens! So, who should I believe? These are the questions new turners will have (myself included!). I can certainly say, from experience, that a razor sharp tool will be your friend while one that is dull will make you wonder why you are having so much trouble getting a good surface on your pen.
In my opinion, a good series on sharpening tools would be great for all pen turners. As a Shopsmith owner, I am using the disc sander attachment to sharpen all of my lathe tools but I am beginning to think I really need to get a good grinder to do a better job of sharpening my tools.
Thanks for starting this thread!
A sharp tool beats the pants off a dull one, hands down. Sadly as yet I have yet to experience razor-sharp tools :(. Once I learn to use a skew properly I may try to hone a nice sharp edge (so far I've been making do with a wolverine jig and a grinder, and using primarily gouges)
-Rick
I hope this ends up stickied, since it answers alot of questions all at once in post 1!
It may be worth mentioning on the "insertion tool" that a wooden pencil can do the trick as well ;)
-Rick
Hi Hank,
Thanks for putting this information together all in one place, It took a weeks worth of searching and put all those discussions together in a layout easier for us who are starting out to comprehend. From a new person here I can only tell you the light bulb did click ON! 190 Watts!!!
This pretty much tells me what to expect to have onhand in terms of equipment setup. In the next few days once you've had time could you go into a little bit about the pen hardware components themselves for instance, suppose I had ordered a Berea Hardwoods Provincial (Retro) pen BUT, instead of using the center band that came with that kit I wanted to use a nicer band with scroll work on it.
Most of the kit data sheets call out the bushing sizes but I'm not sure that would be enough information to know if a certain band would
work or not. It would help idenfity some of the models other than Slimline, It's kind of confusing keeping them straight. Baron, Gentleman, Gentleman II, El Grande, Emperor, Lotus, etc. But I'm working on that now myself I should have it figured out by next week. It would be nice to have a list of some kind. (Who Knows, There might already be one and I missed it.)
I do realize that is another complex task due to all the makers and styles out there but I'm sure most of you already know bits and pieces of that information or at least from the kits you all repeatedly put together.
From your information I already can see that I will need another part for my new lathe before it gets here. That #2MT stuff really is tricky thanks for clearing that up for me. This information has been most helpful.
Regards,
Mike D.
I don't know the difference between Boxelder from Buckeye Burl!
However, In highschool I dated a Buckeye gurl!
(no no no, she didn't dump me! I dropped her!) ;P
Nice list, Hank! I'm a little torn, though - I wish I had this when I started - but on the other hand I understand things a lot better because I didn't have it and had to wait out my impatience and learn through trial an error - an excellent teacher. But I guess that sounds a little like my grandfather telling me if you really want to understand turning you have to start out as a bodger using a foot-powered pool lathe, like this gentleman:
http://www.bodgers.org.uk/gallery/main.php?g2_itemId=1970
Anyway, I agree - in the library!
Excellant information!
Thanks for consolidating all this information into a single, concise reference. I vote for it to be a library item as well. I started penturning a year ago in April and something like this would have been of great help. Beautiful.
Great job Hank
I agree that this would be great in the library, but a special folder for this and a couple other articles. I can think of one other right now. We see this question all of the time. "What is the best finish?" A very ready reference for new pen turners.
A special mention might be given to "cheap, penturning chisels." file those under garbage.
Gee whizz where was this list 18 months ago. Great Job Hank, I agree it should be stickied.
sure could save newbies a lot of trouble and expense.
Hank, this is a very nice list. One to let one know exactly what they are getting into.
But think about this. If this all inclusive list had been around when we started, how intimidated would we have been about spending SO MUCH MONEY just to make a pen?
Very good write up, but like you say, it's a little overwhelming. I think a bare bones list would be:
Lathe
Mandrel
Round nose scraper (I've made 99% of my pens with one)
Pre drilled blank (PSI)
Pen kit
Medium CA (for tubes)
Kit bushings
Misc sandpaper
Clamp (act as a pen press)
That would get you a basic writing instrument. With more equipment you'll get better fit, better finishes, customization, etc but if you just need to know the basics, I'd think that would do.
Skye, I'm doing a bit of a Hmmm not so sure type thing over your post. I understand the minimalist thinking so that you have not piled a boat load of money into turning only to find out it is not for you. But it also would leave you having made a pen and then facing the real expense as well. sort of setting yourself up for delay after delay as you wait to purchase the inevitable. I think Hanks list is a very good and realistic idea of what a new person is really getting into if they really want to get into penturning. I am not arguing just thinking that the minimalist route has pit falls of it's own. If I where a new turner looking at this list I coudl still choose the minimalist approach for myself but still having been fully warned of what I was doing.
I was lucky when I got into penturning and had by far the majority of the tools needed. I still spent $2000 right out the door on pen kits, blanks and the tools I did not already own. keep in mind this made about 100 pens as well as I went straight for the craft show curcuit.
Nice write up Hank and it is really nice to have it all in one place. As I read it I was thinking that it would be great to have each item on your list linked to a tool comparison page. so as they read about the various lathe options that really matter they could then go to the comparison page on lathes.
I am not talking about a page that has opinions on various lathes but a very raw factual this is the features type page. let the group as a whole still serve the pourpose of evaluating the merits of various features. it is somehting that will never be agreed on anyway but information for a first time buyer is usually one of the best things this group can offer.
This very thing (linking) came to my mind when this list popped up again a couple of days ago. If it goes to the Library, some linking would be ideal, IMO.
As for too long, most posts in the "Library" are two, three or 4 pages. People don't have to do all of this, but the outline is there with enough meat on the bones (so to speak) to give an idea where this might be headed if pen sales or serious give-away hobby develops.
I agree. I tried hard to keep personal opinions out. :rolleyes:
I wrote to Scott (Mudder) about revising this. When the Birthday Bash is over and more time is available, hopefully it can get cleaned it up to look and read a little more professional. :wink: It certainly is going to take someone more eloquent than me. :biggrin: Wonder if Cav would help with at least the spelling? :biggrin:
