Dario
I had that problem until today. I tried all fixes I can find from reading here and Russ' page. While some helped a bit, they all failed to really fix my problem.
Closer investigation revealed that my problem is inside my MT2 driver. Somehow, it got gouged inside the driver over the years. What's bad is the gouged metal formed a mole/hill that causes my MT2 mandrel to NOT seat properly and caused it to wobble. And it gets worse as time goes by.
I finally broke down and bought a MT2 reamer like this http://cgi.ebay.com/2-MORSE-TAPER-R...9750270QQcategoryZ633QQtcZphotoQQcmdZViewItem
And I am amazed how fast it solved my problem (2-3 mins). Wish did so much sooner. I highly recommend this product.
Here is a link to my inquiry on how to use it
http://www.penturners.org/forum/topic.asp?TOPIC_ID=12099
I think I will be turning more again soon!!! If and when I find time [V]
[xx(]
Disclaimer: Reamer is not a fix all...it will work for some cases (as I described) and may not on others. I am just sharing this info and not endorsing the seller of the product, thought it is through them that I bought mine. Also check your taper size before ordering
