I received a clear buckeye burl, and a clear curly maple. I finally got the buckeye done. To give an idea of my point of reference, I've never turned acrylic or stabilized blanks, but I have turned corian, Minwax hardened buckeye, and untreated buckeye.
All in all, it's one of the easiest blanks I've worked with so far. It cut cleanly, and the drill went through it like it wasn't even there. I drilled it for a full-sized Majestic, and just took it slow and easy. Turning it was a dream. I had 1 small blowout from a piece that was almost completely surrounded by air. I put it back on with some shavings and CA, and was good to go. I had to stop a few times to fill some voids, but that was to be expected. I find the hardest woods easier to turn smoothly, and this seemed just a bit softer than corian. It was great.
Not want to risk a screw up, I finished with the 80 grit gouge. Here is where my only issue occurred, and that was the final sanding. It was murder getting the sanding marks out, but I got there. It took my usual CA/BLO finish like a champ.
If you're in the market for stabilized blanks, I don't see how you could get any better than what Constant sent me. I'm glad I was able to get in on the trial, and will get the maple done soon.
