Table Saw Blade Question
Focushere
Rockwall
Looking for a Table Saw Blade that cuts so smoothly that I won't have to sand when segmenting. I need one that will work with wood and acrylic. Any Suggestions?
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Besides the Frued there is a Forest II blade thin kerf I use that preforms that well. I also used a 7 1/2 blade on a Makita table saw Im setting up just for just segmentingand small work, that I made the scallops on my last pen with. Its the thinnist kerf I can find. You probably should consider a blade stiffner if you use a 10in blade
sailing_away
Tampa, Fl, USA.
I have both the Diablo and the Forest II (with stiffner) . Both blades cut very well. The 80-tooth 10-inch blade Diablo blade was easier to find at the local Home Depot. I believe it was priced a little lower as well. Either blade will serve you well.
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
several choices
Frued and Forest blades are among the best available and both offer many choices - find a catalog and look through their offerings. You probably do want a very high tooth count and a blade stiffener as suggested above.
tdhove
Hager City WI
I have had great luck using a thin kerf crosscut blade from Freud. I was able to pick it up new on Ebay for about $60 new. I bought it because I wanted a great cutoff blade and bought a second for my table saw as it cuts that clean. It is an 80 tooth blade.
Hope this helps,
Troy
Wood Butcher
Local Chapter Leader
Westfield, IN, USA.
I have several Of the Forrest WW2 blades and a couple of the Freuds and like them all for different reasons. The one I have been using for segmenting is a Diablo by Freud but it's a 7 1/2" blade used on the table saw. Does a super job for around $20 from Dome Despot.
WB
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
It's all about the number of teeth and the feed through it.
Scott (Arkysaw people talkin' 'bout teeth....get it?) B
I have about 15 saw blades. Yes, the tooth count does indeed make a difference but not all 80 tooth blades will cut the same, even if the technique is the same.
I have cheap Frued's and they are ok. I also have expensive, industrial quality Frued's and they cut MUCH better, same tooth count. My favorite, for the absolute best cut, is my Tenyru Gold Medal. It is only a 40 tooth blade but it cuts far smoother than any 80 tooth blade I have both in ripping and cross cut. It will leave an absolutely smooth cut with no visible marks. My next favorite is my Leitz blades.
mpex
Columbus, Ohio
Few questions:
1.What thickness Kerf do yous recommend?
2.Also, I don't see the Forrest Woodworker 2 that seems to be recommended with an 80 tooth count. What tooth count would be recommended for this series?
3.When I looked at the Freud blades, almost all said they were for Circular saws. Are these also for Table saws?
4.I have a 10" Craftsman table saw. Can I use different size blades? Is it better to use a smaller blade if everything I'm cutting is less than 2" thick and mostly just 1" blanks?
Thanks for any help!!!
Wood Butcher
Westfield, IN, USA.
I'm using a '79 Crapsman and for most work I use the Forest WW2, expensive and should only be sharpened by Forest. I have no kerf marks when ripping or cross cutting but I use the 7 1/2" Freud Diablo for segmenting so as not to lose as much material, it has a 1/16" kerf.
WB
Lenny
Searsport, Maine
I agree with Freud and Forest as good brands but in my experience the Diablo version, while a good blade, is a cheaper version in their line. For our purposes as pen makers it makes sense to stick with the thin kerf models. Next you have to ask yourself will I be ripping or cross cutting. If you only want to buy one blade, look at the combinations, probably 40 or 50 teeth. A 80 tooth blade designed for use on a slide compound saw or miter saw will leave a nice cut across the grain but isn't designed for ripping. This is probably the most popular blade for table saws and a good first choice if you only want to buy one blade...
Amazon.com: Freud LU84R011 10-Inch 50-tooth ATB Combination Saw Blade with 5/8-Inch Arbor and PermaShield Coating: Home Improvement
alamocdc
San Antonio, Texas, USA.
I have both a Forrest Woodworker II and several Diablos. I use my Woodworker II for jointing since I don't have a jointer. Very smooth cuts. All of them do great for segmenting.
