Randy Simmons
This review is regarding the Zen rollerball kit from exotic blanks.com. This is not a PSI/woodturningz kit, And I believe it is available at woodturners catalogue
The Zen costs about 13-15 dollars. That is the exotic blanks price for one, not including quantity discounts, and a 10.5mm drill bit and bushing set, about a ten dollar one time expense.
The zen rollerball has a single tube design; you don't need to turn a cap, just the body. It has a magnetic cap that posts easily and securely. The tube size is 10.5mm by about 3-3.5 inches. It has a rounded writing tip which I find to be very comfortable, and when the pen is capped, it forms a seamless cylindrical shape that looks very sleek
Assembling this kit was a piece of cake. There are hardly any parts at all. Just press the female threads into each end of the tube (they are equal diameter too, so it doesn't matter which side you make the front or the back) screw in the writing nib and back magnet piece, which is somewhat small and, again, sleek. On a more technical note, I do wish that it used a 10mm (or similarly universal) tube size so I could use pre-cast blanks such as carbon fiber, but I guess you can't have everything.
You can see pictures here
I like this pen a lot. It writes well, using the same schneider refill that PSI rollerball pens use. The magnetic cap is strong and secure but not too much of a chore to remove. It also has a much sleeker and more refined appearance than the graduate kit.
While it is a little on the spendy end for some beginning turners, you can easily get a hundred dollar pen out of this kit with the right materials. I certainly like it more than the graduate kit from PSI, and I may make this item a stock model of mine (I will certainly order a few more, regardless).
This pen was definitely more than I expected out of it. If you are looking for a magnetic pen, this one is the way to go. Hope this helps! If you have any questions just ask
Cheers!
Cheers!
