Help with Alumilite casting
Forney, Texas
I would like to get some help with some alumilite casting. I have used up my first A&B and had little success and I would like to use up the rest that I have. I will even share what you help me cast so that I can just use this up and get it out of my garage. After this, I will just purchase and leave the casting to the more knowledgeable and the pros.
Any help would be greatly appreciated.
Thanks,
Dan
munawar
Plano, Texas
Dan I just did my first couple of cast with both Alumilite and PR. I spend a long time emailing and talking on the phone with both Alumilite and the two gentlemen I bought my molds from before casting. The only real trick is getting the ratios right and for alumilite you have to go by weight can't go by volume. Anyways, I am in Plano and Forney is a little far but not too bad, if you want to come over with your resin and we can try casting it together if you like. Shoot me an email at munawar@lioncubtrading.com and we can coordinate some time if you like.
Regards
Munawar
