help with ca
fsyxxx
ATX(Austin, TX)
i am in need of someone to help me figure out why my finishes arent coming out. did a few before christmas that were fine but now i can't get i can't get one right to save my life. anybody in the area that could give me some hands on?
greg
Pens By Scott
Calgary, Alberta, Canada
Well, let's start with some questions.
- What type of CA are you using, Thick, Thin, Medium (I prefer Med myself)
- Accelerator? I do use it with very good results, but for some people, it's a mixed bag.
- Are you using BLO (Boiled Linseed Oil)?
- How many layers?
- Do you sand between layers? (I don't)
- Do you Dry Sand or Wet Sand (I wet Sand with MM (Micromesh))
- Do you sand lengthwise between MM grits? (I do, turn the lathe of and sand length of barrel in line with Mandrel, hand turn slowly)
- What speed do you sand at?
- Do you polish after? ( I use a plastic polish after Micromesh)
Let me know via PM if you like.
jedgerton
Austin, TX, USA.
Greg,
I'm in Austin and I think I might be able to help. I only know one of the ten thousand ways to do a CA finish but I can say mine works nearly every time. I'll PM you with a telephone number. Give me a call and I'll see if I can help.
John
