Oklahoma guys - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > Oklahoma
  Forgot Password
Reply
Old 09-29-2017, 08:41 AM   #11 (permalink)
Photos: 5
Default
Welcome from Colorado.
tomtedesco is offline   Reply With Quote Top
Old 10-01-2017, 11:15 AM   #12 (permalink)
Photos: 0
Default
Quote:
Originally Posted by eharri446 View Post
Starting to get leaves dropping and the temps are staying in the low to mid 80's during the day.
Other than that, it is the same here as it is there. Everyone is chasing their dreams.
Persimmon says it's gonna be a wet heavy winter. Not much green left around here. Well, there's green but ya know.
Tried my hand at acrylics the other day. Blew out 4 blanks and stopped. Using a carbide cutter with the circular radius and light passes but I think I dug in too deep. And from what I have been watching online I had my lathe too fast. Had it spinning 3000 rpm. Seems a lot of guys on YouTube have theirs around 1200
bud_008 is offline   Reply With Quote Top
Old 10-01-2017, 04:11 PM   #13 (permalink)
Scissortail Pens's Avatar
Photos: 5
Default
Bud, Welcome from Davis. On the acrylics, using carbide, if you'll turn the cutter about 45 degrees while cutting and taking light passes as you did, it will turn without catching. Takes a little getting used to but it's well worth it. I personally turn them as fast as my little lathe will turn and watch the ribbons fly.
__________________
Dave
Scissortail Pens is offline   Reply With Quote Top
Advertisement
Old 10-01-2017, 06:01 PM   #14 (permalink)
Photos: 0
Default
Good ol Davis Oklahoma! Haven't had me some BBQ from there in a minute. I used to live in Ada. Worked in Pauls Valley. I have a really good friend in Wynnewood and I go back and visit a lot. I also go back that way a lot to referee/umpire. It's a small world.
When you say rotate the cutter, do you mean pull the handle up or **** the tool on its side? I like the looks of acrylic but have yet to fully turn one without blowout
Old 10-01-2017, 07:13 PM   #15 (permalink)
Photos: 64
Default
Make sure that what you have is not Inlace Acrylester. It is extremely brittle and takes a while to learn to turn it.
The best to learn to turn is Acrylic Acetate or AA as you will here it referred to. It turns real easy. Another one to turn is Alumilite. It actually turns like butter and I have never had a catch with either.
eharri446 is offline   Reply With Quote Top
Old 10-01-2017, 07:30 PM   #16 (permalink)
Photos: 0
Default
The blanks I tried were from Penn State. They were already turned round. I also have more of their blanks coming in the mail called "the referee". (Since I'm a ref and know a lot of refs i figure a good gift) and I also have 3 blanks from woodturningz called "the jailbird". Any insight on those?
Old 10-01-2017, 07:43 PM   #17 (permalink)
Photos: 5
Default
While holding the tool straight and level lengthwise, instead of laying the bottom of the tool flat on the rest, twist or "skew" the cutter about 45 degrees as if your turning a combination lock, it makes it more of a skew than a flat scraper and what it's actually doing is making a smaller area that contacts the blank and because it's skewed, it doesn't have a flat area to grab hold of the blank. Yep, Smokin Joes is still here. Had some Sliced brisket sandwiches from them last night.
Also, as Elwin stated, make sure that whether it's inlace acrylester or not, it's a definite learning curve to turning it, it's need to be done with very slow and extremely lights cuts.
__________________
Dave
Old 10-02-2017, 06:10 AM   #18 (permalink)
Paul in OKC's Avatar
Photos: 6
Default
I also turn at highest speed on my lathe, 3600, I think. I use the tool in the same position as with anything else. If you do try rotating, I have found that a bit harder for me because I have to concentrate on holding on tightly to the handle because if I get toward the side of the tool it wants to pull back down flat, but......ymmv. I found on acrylics for me it works best to turn the ends from the inside out. Even with woods I will usually Knock the corners off in the middle then work out to the ends, taking them down close to finish size, then work the middle. Seems to help.
__________________
Paul in OKC, OK
Romans 12:2
Do not conform to the pattern of this world, but be transformed by the renewing of your mind..........
Paul in OKC is offline   Reply With Quote Top
Old 11-07-2017, 09:32 AM   #19 (permalink)
Photos: 0
Default
I would love to get the Ok chapter going again as I have only been turning about 8 months now and could definitely learn a lot from more experienced persons. Live in Edmond, Ok. I do cast my own acrylic now and am having a good time doing it, but still have a lot to learn on that process also. When turning Acrylic, take your time, don't force it and use sharp tools. Just takes a little patience and practice, but well worth it when you master the art.
SJScher is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
