FS: Delta 46-460 Midi Lathe - Kenosha, WI - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > Wisconsin
  Forgot Password
Reply
Old 09-19-2013, 03:28 PM   #1 (permalink)
Photos: 14
Default FS: Delta 46-460 Midi Lathe - Kenosha, WI
This is in Kenosha, WI $699 or best offer
Delta Industrial 46-460 12-1/2-Inch Variable-Speed Midi Lathe --
Product Information
Technical Details
Part Number 46-460
Item Weight 110 pounds
Product Dimensions 34.5 x 21.5 x 14.2 inches
Origin Taiwan
Item model number 46-460
Power Source corded-electric
Item Package Quantity 1
Warranty Description 5 Year Warranty
Shipping Weight 110.2 pounds (View shipping rates and policies)
Date First Available December 8, 2009
Product Description from Amazon.com
Featuring a ball-bearing live center, heavy-duty steel knockout bar, and onboard storage for easy access to adjustment tools, the Delta 46-460 industrial 12-1/2-inch variable-speed midi lathe handles even heavy-duty jobs with ease. Ideal for professional woodworkers, this machine gives you fast, smooth results and offers variable speed for consistency and control.
Callout box top
Industrial 12-1/2-Inch Variable-Speed Midi Lathe
At a Glance:
Powered by a 1-horsepower max, 1,725-rpm motor for robust performance
12-1/2-inch swing capacity--the largest in its class
Variable speed with three pulley-speed ranges
Includes 6- and 10-inch tool rests and 3-inch face plate
Backed by a five-year warranty
The extension bed increases the overall bed length to 42 inches.
Powerful Motor and Variable Speed for Consistency and Precision Powered by a 1-horsepower max, 1,725-rpm motor, the Delta 46-460 industrial 12-1/2-inch variable-speed midi lathe provides a 12-1/2-inch swing capacity--the largest in its class. Variable speed with three pulley-speed ranges makes it easy to select the required speeds needed to turn a project without changing belt position.
Forward and Reverse Provides a Superior Finish
For accuracy and precision, forward and reverse functions allow the turner to achieve a superior finish. As woodworkers know, sanding a turned piece with the grain causes the wood fibers to lie down and remain rough while sanding a turned piece against the grain will shave the wood fibers smooth. Rotating the turned piece in both directions is the way to achieve a truly smooth finish, yet it often involves remounting the work piece backwards--a time-consuming and often impossible task. With the 46-460, this process is simplified. With a quick flip of the switch, it's done.
Patented Belt-Tensioning System for Fast Speed Changes and Longer Tool Life
A patented belt-tensioning system makes for quick speed changes, and sets the belt at the correct tension every time for maximum power transfer and longer tool life. And large objects are no problem with the six-groove belt that provides superior power for effortless turning.
Cast-Iron Construction for Durability and Strength
Durable and stable with all cast-iron construction, the 46-460 also includes a three-inch face plate, and 6-inch and 10-inch tool rests for tool support in a variety of turning applications.
Warranty Information
The Delta 46-460 industrial 12-1/2-inch variable-speed midi lathe is backed by a five-year warranty.
What's in the Box
12-1/2-inch variable-speed midi lathe, 6-inch and 10-inch tool rests, chrome 3-inch face plate, tool rest base, knockout bar, live center, wrenches, and manual.
DELTA 46-460 Industrial 12-1/2-Inch Variable-Speed MIDI LATHE
Variable speeds let you perform a variety tasks without changing the belt position.
Includes all original accessories...
Lathe Delta 46-460 electronic variable speed includes the basic lathe package:
•Face plate
•Wrenches
•Live center
•Spur drive center
•Two tool rests
...also includes optional equipment:
•Bed extension Bed Extension #46-463 $135 on AMAZON
•Lathe Stand #46-462 $60 on AMAZON
•Stand Extension #46-464 $80 on AMAZON
•Spare drive belt
•Spare reverse switch
On Amazon, the lathe sells for $700. Add in the legs, leg extension and bed extension (total $375) and you have a total Amazon price of $1,075.00
But it is all yours for just the Amazon price of the lathe itself, $699! Or best offer.
__________________
Marc
Kenosha, WI
Paladin is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
