Help cutting up box elder - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Local Chapters > Indianapolis
  Forgot Password
Reply
Old 10-11-2017, 04:38 PM   #1 (permalink)
Dalecamino's Avatar
Photos: 219
Default Help cutting up box elder
Can I get someone to help cut a couple of short logs into blanks? One is 7 x 19, the other is 7 x 24 Both have some burls in them.
Any help would be appreciated.
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Old 10-11-2017, 11:50 PM   #2 (permalink)
robutacion's Avatar
Photos: 4
Default
G'day mate,
I believe the measurements are in centimetres, right..?
Regardless of the unit of measurement, if you have a big enough bandsaw, you can start by cutting them in half and then each half into half again, if the bandsaw is not big enough for these first cuts, you can use a chainsaw to slice them in half and then continue one with the bandsaw.
After the logs are cut into 4 quarters, you have to decide what type cuts you want, if straight-cut/with the grain, you slice each quarter into boards of the thickness you see more appropriate if the wood is dry anything about 20mm is sufficient, however, if the wood is green/wet,etc., you need to allow for shrinkage as it dries so about 1" thick is normally enough.
If the wood needs drying, stack the blanks on top of each other in a cross type orientation, this will allow you to create a "tower" that you can then strap down to keep it together and put it away under cover but with some ventilation/air going through it.
If you have any further questions, I will be here...!
PS: Pics are always welcome
Cheers
George
__________________
"Don't give others what you don't like for yourself"
Email: nyodine@yahoo.com.au
Web-Store: https://www.georges-bits-of-timber.com/
robutacion is offline   Reply With Quote Top
Old 10-12-2017, 12:09 AM   #3 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Thank you George! These are inches. They are a bit too big for my bandsaw. And I need a new chain for my chainsaw. I thought someone here in my area might have a floor model bandsaw that could knock out some blanks in a short time.
I appreciate your advice. Interesting procedure.
__________________
Chuck Hutchings
Indianapolis, In.
Advertisement
Old 10-12-2017, 07:01 AM   #4 (permalink)
robutacion's Avatar
Photos: 4
Default
Inches huh...? that's OK, that means that they are a little bigger than what I thought but still most workable unfortunately I'm too far away to get it done for you, that would be a piece of cake for me but, no go, sorry.
I hope you find someone to give you a hand with them.
Cheers
George
__________________
Old 10-12-2017, 09:49 AM   #5 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Cheers
George
Thanks again George! I think this thread just needs a little more exposure.
__________________
Chuck Hutchings
Indianapolis, In.
Old 10-12-2017, 12:27 PM   #6 (permalink)
EBorraga's Avatar
Photos: 78
Default
Hey Chuck, also post in the indy chapter. maybe a local will read it and help out!!!!!
__________________
Wicked Chickens lay deviled Egg's
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is offline   Reply With Quote Top
Old 10-12-2017, 02:37 PM   #7 (permalink)
Dalecamino's Avatar
Photos: 219
Default
Quote:
Thanks Ernie! This IS Indy Chapter I think!
__________________
Chuck Hutchings
Indianapolis, In.
Old 10-12-2017, 03:43 PM   #8 (permalink)
EBorraga's Avatar
Photos: 78
Default
Must be the drugs Somehow I thought it was Casual Conv.
__________________
Old 10-12-2017, 05:30 PM   #9 (permalink)
Dalecamino's Avatar
Photos: 219
Default
LMAO! I can do that without drugs
__________________
Chuck Hutchings
Indianapolis, In.
Old 10-12-2017, 08:26 PM   #10 (permalink)
rej19's Avatar
Photos: 9
Default
Chuck, if you get them to fit a 6" shopsmith I'd be glad to help.
Ron
__________________
Ron in Indy
rej19 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
