Derek is once again in charge of The Turning Challenged Contest.
This is a great contest if you havent turned a lot of pens or struggle to get the results your looking for.
Read them over and ask any questions or make any suggestions you may have.
Default Contest for the Turning Challenged
This contest is for those who are just starting out turning pens as well as those of who have been doing it for a while, but just haven't mastered it yet. Here is a quick self assessment to determine if this contest if for you.
If I say "How is the Fit and Finish?" and your response is " Better than the Fat and Norwegian".
You're not quite sure what "outgassing" is, but you pretty sure it involves refried beans.
You wonder why California is the only state that gets a finished named after it.
The only reason you use a skew is to keep up on the latest swear words.
You've glued any part of your body to either yourself or anything in your shop in the last month.
If you answer yes to any of these questions, this is your contest. So now that you have determined that this is indeed the contest for you. Here are the guidelines:
1. A Slimline or variant must be used for this contest. Basically if it has a 7mm tubes, a twist 7mm tranny, and two equal length tubes, it's eligible. This includes Creekline, Saturn, Funline, Streamline, and Trimline kits.
2. You may not use the center band of kit. You may either simply eliminate it or you could make a custom centerband. Here is some reading on making custom center bands.
3. To keep the playing field level.....
Wood Lathe - Yes
Metal Lathe - No
Ornamental Lathe - No
Rose Engine Lathe - No
CNC - Oh H#ll No
4. Blanks for this contest must either be:
Commercially available
Made by you from raw materials, where the work by you represents the majority of the work required to create the blank.
5. The pen cannot have been or be shown in any public forum (truck stop bathrooms included) before the contest is completed.
6. The deadline: Has not been determined yet.
7. To enter use this entry form, which is also located on the IAP front page.
8. Winners will be determined by IAP membership.
So there it is. Have some fun, talk a little trash, and make some pens.
Questions? Post them below or if you prefer PM me.
Wood Lathe - Yes
Metal Lathe - No
CNC - Oh H#ll No
