Suggestions on respirators - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 05-31-2018, 10:10 AM   #1 (permalink)
Photos: 0
Default Suggestions on respirators
Can anyone suggest a good respirator to use for turning, sanding and buffing wood and acrylic? Thanks!
Upinsmoke9 is offline   Reply With Quote Top
Old 05-31-2018, 12:07 PM   #2 (permalink)
jttheclockman's Avatar
Photos: 83
Default
Quote:
Do you have a good dust collector system set up for the lathe or for where you are sanding things.
What type turning are you doing?? Is it just pens?? If you are doing things like pens, spin tops, bottle openers and small items, all I use is a nuisance dust mask and either safety glasses or a face shield. I have dust collection and do not do large items on my lathe.
If I do anything larger I have a Trend Airshield Pro.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 05-31-2018, 12:26 PM   #3 (permalink)
Photos: 0
Default
I’m only turning small things- mostly pens right now. I am going to set up my dust collection system to the lathe, so that should help too. I’ve just been reading that micro sanding and using a buffing system should include some sort of respirator usage. Thanks for your thoughts and reply!
Advertisement
Old 05-31-2018, 12:42 PM   #4 (permalink)
Photos: 0
Default
This is the one I use https://smile.amazon.com/gp/product/...rch_detailpage.
It's reasonably comfortable, has the quick release I like and you can put charcoal filters (or combo filters) if you are doing finishing work.
RileyD is offline   Reply With Quote Top
Old 05-31-2018, 10:14 PM   #5 (permalink)
Photos: 0
Default
Great, thank you. Is there a particular filter that you use with this respirator? 3M 2097 or 3M 2297 filter?
Old 06-01-2018, 11:57 AM   #6 (permalink)
Photos: 0
Default
The 2097's. Biiig pink circles.
Old 06-01-2018, 04:56 PM   #7 (permalink)
Photos: 0
Default
For light duty, I use a Resp-O-Rator. It's less bulky and doesn't get in the way of safety glasses, mask, or ear protection.
Resp-O-Rator - Duxterity LLC
When working with fine dust or more problematic materials, I go with a 3M like the one listed above. Even with a beard, it works well when cinched up tight.
I also often wet sand, which helps trap a lot of the dust.
cjester is offline   Reply With Quote Top
Old 06-03-2018, 08:49 AM   #8 (permalink)
Photos: 0
Default
Thanks for the information!
Old 06-03-2018, 09:21 AM   #9 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
It has been my own personal experience AND observation of the need of people on this forum that there is a wide range of specific needs and in the end each individual must match the specific respirator to their own needs.
1. Many people here get by with the white dust mask type; some use the face mask approach that have a valve.
https://www.amazon.com/Universal-Non...ust+face+masks
https://www.amazon.com/dp/B078GN1G1Z...&pd_rd_w=xqRzC
2. Then there are the kind RESPIRATOR kind as mentioned and linked by RileyD
I have used these types for years.
3. there are the full face mask type that run close to $100 such as this one:
https://www.amazon.com/Holulo-Respir...ds=respirators
the problem with this one is there is no air circulating inside and unless in an air cooled shop, it will get sweaty.
3b. This type below, and there are two or three brands of different varieties that have air flow in them. They use battery packs for the air flow. I had a Triton that I used for a while (about 10 years ago) but it had nicad batteries that eventually quit working. replacements were too expensive.
https://www.amazon.com/TREND-AIR-PRO...rds=air+shield
4. Then there is the one that Cjester linked to - some people like it just fine; others not so much.
The type needed depends upon your physical needs. I am not huge 220lb, 5'10" and not really barrel chested but have big lungs. I have climbed 12,000 to 14,000 ft mountains and never got short of breath while others with me would struggle for breath; the point behind that is that my lungs seem to grasp a lot of air. I cannot wear those white mouth/nasal masks as air shoots out and fogs my glasses, even with the glasses coated with anti-fogging cleaners. I cannot wear a full face respirator without air circulating or the mask will fog up in a couple of minutes. The Triton mask worked great as long as the batteries were working. For me, and some others here, the ones like Riley mentioned work well. I have three. I always keep two on hand, but lost one set (stored it in a box and recently found it again.
Hope this helps.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 06-03-2018, 10:06 AM   #10 (permalink)
Photos: 0
Default
You can get this dual particulate/vapor cartridge for this mask:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Gary
__________________
Gary Walz, Vermont Wood'n Pen
Milton, Vermont
vtgaryw is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
