Rpms for Penturning - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 05-28-2017, 05:10 AM   #11 (permalink)
Photos: 8
Default
Quote:
Originally Posted by Texasshipagent View Post
Depends on material and cut making
Sent from my iPhone using Tapatalk Pro
Care to expand on this?
Mortalis is offline   Reply With Quote Top
Old 05-28-2017, 05:51 AM   #12 (permalink)
KenV's Avatar
Photos: 0
Default
I have a 2 hp lathe with 2 pulley settings. I do most all turning on the slower high torque setting. With variable speed, I seldom need to change the pulley.
Have done hundreds of pens and never had a problem attributed to lack of speed. If anything, too much speed with some chippy materials. Specs say I am getting about 2000 rpm.
Lack of vibration with the big lathe is the big plus. (I have a Jet 1014 vs where I snowbird so I know the difference).
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 05-29-2017, 02:00 PM   #13 (permalink)
Photos: 0
Default
Just depends on what you are turning and what material and what step in the process
Texasshipagent is offline   Reply With Quote Top
Advertisement
Old 05-29-2017, 02:40 PM   #14 (permalink)
BURLMAN's Avatar
Photos: 10
Default
If the belt changing schematic on my Delta midi is correct, my top speed is 4000 rpm. That's what I turn at. No problems.
BURLMAN is offline   Reply With Quote Top
Old 05-29-2017, 04:09 PM   #15 (permalink)
KenV's Avatar
Photos: 0
Default
Coy,
As you shop, do not neglect the bottom end speeds. While some like to use abrasives or emblishments at high speeds, I find I get better results and avoid heat checks and softening with slower speeds on the lathe -- letting the abrasive do the work, or doing the embilishment treatment at slow speeds with better control.
Spindle lock (different from index pin) is handy too.
__________________
Ken Vaughan
Old 06-06-2017, 06:56 PM   #16 (permalink)
Photos: 0
Default
I agree with coysquiggly, keep your tools as sharp as you can. I've turned at lots of different speeds. But usually at around 1800.
jdclaus is offline   Reply With Quote Top
Old 06-07-2017, 10:28 AM   #17 (permalink)
Photos: 0
Default
I turn between 1100 and 2800 because I have a 3 step pulley variable speed lathe and I can do everything at the middle pulley position. I turn, sand and apply CA in that range.
wouldentu2? is online now   Reply With Quote Top
Old 06-07-2017, 10:56 AM   #18 (permalink)
Photos: 0
Default
I have 3 lathes and live by the motto you can turn small on a large lathe but you cant turn large on a small one. mine are a 9",13" and a 16"
Artisan iron designs is offline   Reply With Quote Top
Old 06-07-2017, 11:48 AM   #19 (permalink)
duncsuss's Avatar
Photos: 1
Default
I'm quite happy making pens with the spindle turning anywhere above 500 rpm. (I prefer it higher, usually between 1,500 and 2,500 but it doesn't matter to me.) To say you *must* have 3,000 rpm is ridiculous.
__________________
Duncan Suss
website: FruitOfTheLathe | facebook: FruitOfTheLathe
duncsuss is offline   Reply With Quote Top
Old 06-07-2017, 11:56 PM   #20 (permalink)
Photos: 0
Default
I can't understand why people turn so fast. I turn my pens at 1400 and never have a problem. I go to 1800 for final polishing. My last resin blank I turned, I ran the lathe at 700 rpm and had no problems at all. With sharp tools and proper technique, just about any speed will work.
Typos courtesy of my iPhone
AnB_Daddy is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
