Rpms for Penturning - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 08-24-2016, 08:24 PM   #1 (permalink)
Coysquibbly's Avatar
Photos: 0
Default Rpms for Penturning
Looking for a new lathe and perhaps a bigger one. i have turned at least a 1000 pens and turned most of them on my small lathe that goes to 3200 rpm usually run it about 2700
My larger lathe I have turned pens on, but it only runs to 2000.
Thoughts, preferences and I do understand that most people turn at a speed they are comfortable with.
Kindest regards,
Coy
Coysquibbly is offline   Reply With Quote Top
Old 08-24-2016, 08:27 PM   #2 (permalink)
Photos: 1
Default
I turn pens and other things as fast as it will go. Pens are always at 3500RPM
__________________
Keith Byrd, Milford, MI 48380
Keith@turningbyrd.com
www.turningbyrd.com
www.facebook.com/turningbyrd
keithbyrd is offline   Reply With Quote Top
Old 08-24-2016, 08:33 PM   #3 (permalink)
Photos: 0
Default speed
Kindest regards,
Coy
I turn slower to start, until I have to square edge's off.
Frank Nemke sr is offline   Reply With Quote Top
Advertisement
Old 08-24-2016, 08:33 PM   #4 (permalink)
mrcook4570's Avatar
Photos: 0
Default
For pens, turn it high and let the shavings fly!
__________________
Stan in WV
Laser Engraving
http://www.mestaridesigns.com/turners
http://www.engravingcave.com
mrcook4570 is offline   Reply With Quote Top
Old 08-24-2016, 08:36 PM   #5 (permalink)
Photos: 0
Default
The lathe that I am looking at only goes to 2400 rpm but it is full size and would be great for bowls. I don't feel that is enough for pens.
Old 08-24-2016, 09:40 PM   #6 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
As you know, bowls require slower speeds, but pens generally work better at much high speed.
The circumference speed of a 12 inch bowl turning at 500 RPM would be about 18 miles per hour. It probably needs to slow down to 400.
A 1 inch diameter blank will be turning at the speed of 1.4 miles per hour at 500 rpm. Pens need to turn at least 4 to 5 times faster RPM than a 12 inch bowl
My math may be off because of aging but I don't think it is off by too much.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is online now   Reply With Quote Top
Old 08-24-2016, 10:05 PM   #7 (permalink)
jttheclockman's Avatar
Photos: 77
Default
You can very easily turn pens at that speed. It is something you may need to just get used to. Heck they turn pens on lathes operated by your feet
Or just keep 2 lathes.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 08-24-2016, 10:17 PM   #8 (permalink)
Photos: 0
Default
s
So Hank, I am guessing that by your math, 2500 rpm would be acceptable.
thanks for the input.
Old 08-24-2016, 10:21 PM   #9 (permalink)
Photos: 0
Default
Thank you all for your input. Its a tough call. I know a lot of guys that say you have to have 3200 + rpm. I think sharp tools are the key. I don turn a lot of cast blanks and i don't want to buy another big lathe if it is not optimum.
Coy
Old 05-28-2017, 01:23 AM   #10 (permalink)
Photos: 0
Default
Depends on material and cut making
Sent from my iPhone using Tapatalk Pro
Texasshipagent is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
