Joining Acrylics - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 09-18-2017, 02:11 PM   #1 (permalink)
Photos: 0
Default Joining Acrylics
I turn a lot of acrylics. I recently purchased blanks, one of which is stars and the other is stripes. I want to "join" them to make a single stars and stripes blank. I have a relatively simple set up (lathe, band saw, disc sander, drill press. I know the key has to be to have the ends exactly square in order (for what I would think is CA) is applied so that it looks seamless. I don't have a fixture for holding a parting tool on the lathe to square the end. I do not have a fixture that will guarantee holding the blank square to the disc sander. Is there a suggested trick in making sure this works?
Thanks much for your help
mikefoye is offline   Reply With Quote Top
Old 09-18-2017, 02:52 PM   #2 (permalink)
Photos: 0
Default
there's a couple of different types of acrylic adhesives out there. the ones I use go by the brand name of Weld-On and are widely used by the aquarium industry. Weld-On 4 is a clear, water thin solvent cement that softens the surfaces that are to be joined. It evaporates quickly and gives fast bond strength. The other I'm familiar with is Weld-On 40 and is a two part acrylic adhesive. It's optically clear, incredibly strong but it's noxious stuff. It has a pot life of about 20 minutes. There may be other adhesives that work but the above are specifically designed for acrylic.
This is a 70" tall piece I made out of hundreds of layers of acrylic using Weld-On 4.
Don't know why my photos show up sideways.
jcjc is offline   Reply With Quote Top
Old 09-18-2017, 03:17 PM   #3 (permalink)
Photos: 0
Thanks for the advice on adhesives. I am concerned on squaring up the blanks perfectly before gluing them together. I would then have a good blank to then center drill for the brass tube.
Advertisement
Old 09-18-2017, 07:26 PM   #4 (permalink)
Photos: 1
Default
Mike,
I have done what you want to attempt. Today I use my disc sand to square the ends. However when I first tried this I used a pen blank trimming kit sold by Penn State. I clamped the blanks in the sled and used the supplied saw. I used ca to glue them together however I would recommend epoxy. After I applied the ca I clamped them together the long way and let dry for 24 hours. After you turn your blank you cannot detect that you used two blanks. Quite a few people were surprised when I told them this. I hope this helps.
Seven
__________________
Over the years I have learned that there are only three types of people in this world....those who can count and those who can't.
studioseven is offline   Reply With Quote Top
Old 09-18-2017, 07:36 PM   #5 (permalink)
Photos: 0
Default
If it is Plexiglas, back when I was in school in the early 1960's, we used acetone to dissolve the Plexiglas to glue it together. It resulted in a clear joint. Does anyone know if acetone will dissolve the cast resin blanks?
dogcatcher is online now   Reply With Quote Top
Old 09-18-2017, 09:15 PM   #6 (permalink)
Huzzah's Avatar
Photos: 0
Default
I've done this as well and start by cutting each piece to length, then drill the holes for the tube. I square up the ends to be glued with a sanding disk on a face plate and transfer punch in the tailstock. I then use epoxy to both glue the tubes in and the pieces together, all at the same time. I then put a piece of parchment paper around the blank and clamp it on the ends to keep the pieces tight, the tube keeps them aligned.
One other pointer I'll give you to save you some aggravation is to make sure you trim the stars so that you have all whole stars where it meets the striped blank. It looks real bad when there is half of a star right next to a stripe, found that one out the hard way.
Huzzah is offline   Reply With Quote Top
Old 11-25-2017, 06:46 PM   #7 (permalink)
Beautys_Beast's Avatar
Photos: 0
Default
Cut the blanks to the right size leaving a little extra and then barrel cut the ends, before gluing them together. Then place them on the lathe, put the center bushing between the two, turn them down till you have gotten to the area that is barrel cut. Now you have two tubes, perfectly squared on the ends. Take the center bushing out, and while still on the mandrel, glue them together. You can even use the lathe as a "clamp". The tubes are perfectly lined up, and the ends are squared.
How to do you square off your blanks now?
Beautys_Beast is offline   Reply With Quote Top
Old 11-25-2017, 09:52 PM   #8 (permalink)
StumpyThumb's Avatar
Photos: 0
Default
Are your factory edges square? You could make your cuts, then glue the factory edges together.
Sent from my SM-N910P using Tapatalk
StumpyThumb is offline   Reply With Quote Top
Old 11-27-2017, 12:16 PM   #9 (permalink)
Photos: 0
Default
Or you could buy a really small Miter box and hand cut, so you ensure the blanks are square.
Like this
https://www.homedepot.com/p/Stanley-...600D/100034395
__________________
"True happiness only comes through gratitude, the alternative is angry self entitlement"
Old 11-29-2017, 10:54 AM   #10 (permalink)
Rifleman1776's Avatar
Photos: 0
Default
Quote:
Lotsa things out there called 'resins'. I really don't know. But acetone will dissolve almost anything it comes into contact with. Plexiglas/acrylic scraps dissolved in acetone will make a good glue at very small cost.
__________________
Frank
Mountain Home, Arkansas
"All animals are equal, but some animals are more equal than others." from Animal Farm by George Orwell
Rifleman1776 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
