Jet 1236 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 06-13-2017, 10:57 PM   #1 (permalink)
Photos: 4
Default Jet 1236
I'm looking for Opinions. Is a jet 1236 a good lathe? I found a used one in good condition.
Kurt Koehler is offline   Reply With Quote Top
Old 06-14-2017, 12:08 AM   #2 (permalink)
jsolie's Avatar
Photos: 9
Default
I have one and have made a lot of pens with it.
It has a #2 MT headstock and tailstock, and 1"x8 TPI spindle, so it's easy to find chucks, mandrels and other accessories for it. Both the headstock and tailstock will allow things to go all the way through, so you can set it up with drawbars or vacuum systems.
It has a Reeves drive and it sometimes needs to get mostly taken apart and cleaned. The pulleys are cast aluminum and will shatter if mishandled. If the lathe changes speed smoothly and the headstock and tailstock are aligned, it'll work. It does not run in reverse, so keep that in mind if you want to turn other things.
Also, it's slowest speed is 550 RPM which is too fast for large out of round things. The green/blue colored ones are the older ones, and they changed the color to white a few years after I bought mine.
Mine is set up right now with a Beall buffing system in it.
Hope this helps.
__________________
-- John
jsolie is offline   Reply With Quote Top
Old 06-14-2017, 12:29 AM   #3 (permalink)
Photos: 4
Default
Thanks for your time!
Advertisement
Old 08-11-2017, 03:22 PM   #4 (permalink)
Tom Walter's Avatar
Photos: 0
Default
Quote:
I have a Jet 1221VS and love it. I would certainly buy another. I have 5 lathes and the Jet is my favorite.
Tom Walter is offline   Reply With Quote Top
Old 08-11-2017, 04:46 PM   #5 (permalink)
KenV's Avatar
Photos: 0
Default
Look very closely at the reeves drive. If it has been maintained well it will look pretty clean and the sheeves should move easily when running. The drive is the weak spot and parts are reported to be coming hard to find.
If in doubt pass on a price much higher than free.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
