HELP!!!--Question about my pen turning--PEN BLANK STOPS!!! - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 03-23-2017, 03:21 PM   #21 (permalink)
More4dan's Avatar
Photos: 5
Default
When you stop by Woodcraft, bring your mandrill and have them show you how to it set up on a lathe. I'm sure there is someone there that can walk you through it first hand.
More4dan is offline   Reply With Quote Top
Old 03-23-2017, 03:28 PM   #22 (permalink)
Heather's Avatar
Photos: 0
Default
This happened to me a few times. My blank has come unglued from the tube..
Heather is offline   Reply With Quote Top
Old 03-23-2017, 03:50 PM   #23 (permalink)
Photos: 0
Default
Yes, you're missing bushings. The spacers that came with the mandrel saver are just to fill the space between the bushings and the mandrel saver so that you don't have to bring the tailstock as far to engage. The spacers aren't always necessary, but the bushings will be necessary. I may have missed the type of kit you're turning, but anything other than a 7mm slimline will do exactly what you're explaining is your issue. And even the 7mm kits may do this as well, not certain.
So you do need the bushings that are specific to each type of kit you are turning. The tube fits onto one end of the bushing, and you turn the blank to the size that doesn't fit into the tube, if that makes sense.
Hope that helps.
iMattDaddy is offline   Reply With Quote Top
Advertisement
Old 03-23-2017, 04:15 PM   #24 (permalink)
Photos: 0
Default
I have a problem like that and the glue wasn't holding
__________________
Archie R. Jacobs
hombre4 is offline   Reply With Quote Top
Old 03-23-2017, 04:26 PM   #25 (permalink)
Photos: 49
Default
It seems odd you can tighten the tail so much that the blank cracks. If the end of the blank shows shiny brass, then you would have to be collapsing the brass tube. My tailstock slips well before that much pressure. If the ends are not square, perhaps the bushings (or spacers) are not seating well enough on the blank and allow slippage.
It's hard to tell from the pic but are ou trying to turn an acrylic? Perhaps starting out with wood might be easier.
carlmorrell is offline   Reply With Quote Top
Old 03-23-2017, 06:19 PM   #26 (permalink)
jsolie's Avatar
Photos: 9
Default
Hi Diane,
First, glad you sorted out your problem!
Charlie W touched on this, and this might be something to consider for the future. When I started out with pen turning, I was using the tool rest that came with my lathe.
As I began to progress, I was finding that I couldn't get the tool rest close enough to the piece being turned and there was a bit of distance between my tool rest and the piece. I began to notice some vibration, especially when getting close to the bushings.
Then I had two blanks blow up on me. One was due to insufficient adhesive, the other was from this vibration (I think). At this point, I bought a different tool rest that was maybe 3 or 4 inches along the top (the post was the same diameter and length as the factory one).
This new tool rest allowed me to get as close as I wanted to the blank, and the vibration stopped as the tool overhang got a lot less.
So, now that you have a nice mandrel saver, at some point you might want to consider a new shorter tool rest.
Take care,
__________________
-- John
jsolie is offline   Reply With Quote Top
Old 04-20-2017, 03:10 PM   #27 (permalink)
Photos: 0
Default
It looks like the mandrel saver is in the headstock. This should be in the tailstock and the other end of the mandrel in the headstock.
rbrazil is offline   Reply With Quote Top
Old 04-20-2017, 03:33 PM   #28 (permalink)
jttheclockman's Avatar
Photos: 83
Default
https://www.youtube.com/watch?v=4z1HNgAJ7z4
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 05-06-2017, 08:10 AM   #29 (permalink)
jrc
Photos: 4
Default
I tried the pen saver mandrel but did not like how much I had to tighten to stop the blank from turning. A good idea but does not work well. No longer use it.
__________________
Jim in Vermont
jrc is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
blank , bushing , mandrel , pen , tail stock
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
