HELP!!!--Question about my pen turning--PEN BLANK STOPS!!! - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 03-23-2017, 12:16 PM   #11 (permalink)
Photos: 0
Default
Diane...........Go to Exotic Blanks. Ed has a bunch of videos that explain how to make a basic pen. Watch them and see if you are doing something different.
You really are doing the right thing by asking questions. No such thing as a dumb question. Easier to deal with then an accident
IF it is a spacer or bushing problem.......you will see it right away.
Keep us informed.
__________________
It's not "Having what you want"......it is "Wanting what you have".
"Don't go riding on that long black train."
stonepecker is offline   Reply With Quote Top
Old 03-23-2017, 12:17 PM   #12 (permalink)
Photos: 19
Default pix
pix attached
Diane is offline   Reply With Quote Top
Old 03-23-2017, 12:25 PM   #13 (permalink)
Photos: 19
Default
thanks--all--I've learned several things today--upload pix by 'go advance'; 'quick reply' to answer questions; spacers are NOT bushings; and most of all--everyone here is so friendly & helpful especially to 'newbies'--I'll order bushings now! maybe when we return from vacation I'll have the 'bushings' and will finally be able to turn & make my FIRST PEN!!!
YA'LL ARE THE BEST!! Thank you again,
Diane
Advertisement
Old 03-23-2017, 12:27 PM   #14 (permalink)
Photos: 19
Default
Also I'll check out Ed's videos --TY so much!
Old 03-23-2017, 12:28 PM   #15 (permalink)
mecompco's Avatar
Photos: 10
Default
Quote:
Originally Posted by Diane View Post
pix attached
I'm assuming you have a brass tube glued into the blank. Those "spacers" are what are used for Slimline pens (7mm). If the blank is tubed, and the mandrel is tightened, then I can't see how the blank can still spin. Now if there were no tube in it, really, it still ought to spin (though not true) as the spacers put pressure on it. If you are making any other type of pen, then you will want the proper bushings as those "spacers" will go right up inside a larger tube.
Regards,
Michael
mecompco is offline   Reply With Quote Top
Old 03-23-2017, 12:29 PM   #16 (permalink)
Photos: 0
Default
anyone located near you Diane that is a member here would probally let you watch them make a pen. One thing I see right away is that your rest is bigger than most of us would use. Not saying it can't be done but a smaller rest would get closer to the work and make it safer for you.
Have a great vacation.
__________________
Old 03-23-2017, 12:35 PM   #17 (permalink)
Photos: 19
Default
good idea!!!I have a smaller one but didn't change it out--I'll start using it when doing small turnings--thank you for your suggestion
Also, when we go through Birmingham, we're stopping off at WoodCraft store as a stop on our vacation
Old 03-23-2017, 12:39 PM   #18 (permalink)
jttheclockman's Avatar
Photos: 83
Default
There is so much info still left out. I see one blank on the mandrel in that photo. Still do not know the kit being used. Also how did you glue the tube in?? What glue did you use to glue the tube in?? Did you square the ends??? How did you square the ends??? From the photo the blank did not have the corners knocked off. Also not knowing your turning skills it maybe you are presenting the tool below the blank too much. As we all get acquainted more things like this work themselves out. Just a feeling out process to help you better.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 03-23-2017, 01:06 PM   #19 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Hi Diane,
I see from your pic that you have an offset tool rest holder in the banjo. For most turning, simply use the tool rest right in the banjo. Your current setup will allow for some chatter of your cutting tool/chisel as the force of the cutting is not directly supported by the banjo.
You have an excellent penturner between you and Birm. His name is Phil and he is in Columbiana. His IAP name is firewhatfire.
The good folks at the Pelham/Birm Woodcraft can also help you out.
Good luck!
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 03-23-2017, 02:22 PM   #20 (permalink)
Photos: 0
Default
Keep us informed.
Correction: There is such a thing as a dumb question It's one I don't know the answer to LOL
larryc is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
blank , bushing , mandrel , pen , tail stock
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
