Ebony Cracking problem - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Old 02-02-2017, 08:47 AM   #1 (permalink)
Photos: 0
Default Ebony Cracking problem
I'm still new to pen turning and I was wondering if Ebony is particularly prone to cracking. I have made pens out of Rosewood, Amboyna Burl, Eucalyptus Burl, Acrylics, and a few other woods and have had no problem with cracking when assembling the pens. However, I have twice turned and tried to assemble an Emperor pen made from ebony and it cracked both times. Does anyone have any tips?
thanks in advance.
rjrotermund is offline   Reply With Quote Top
Old 02-02-2017, 09:44 AM   #2 (permalink)
RobS's Avatar
Photos: 81
I've made 3, 2 cracked. The last one I threw in the oven at 200F and let it dry out for 4 hours, then kept it in a ziplock bag until it was time to turn it. That one did not crack.
Other tips go slow when drilling or it will burn and cause structural problems.
Oceanside, CA
RobS is offline   Reply With Quote Top
Old 02-02-2017, 10:13 AM   #3 (permalink)
Photos: 7
Right after drilling, I would seal the interior of the blank with a liberal layer of thin CA, to help stabilize it ... then re-drill it to clear out any excess CA buildup before gluing in the tubes.
I would also definitely opt for sanding the ends square to the tubes, rather than using any kind of end mill. I also stabilize the ends of the blanks right after this step with more CA.
Lastly, no matter what finish I was planning on, stabilizing the exterior of the blank with CA and then sanding it back to expose bare wood works decently well, if you plan to give it a more natural look and feel, or just give it a dozen coats and sand it glassy smooth all the way up through micromesh, with the polish and buffing of your choice. Comes out looking like shiny black plastic, but still turns heads when they feel it's weight and realize it's really Ebony. I like the Massaccar Ebony, it has some lovely golden tones streaking through the black.
I also never use any kind of accelerator. Many people do, and many dont ... some have issues with or without it. I've also never yet had a pen barrel crack on me. (knock on wood)
Click Here to go to Pen Turner's Anonymous Meeting
Attendance is not mandatory, unless you're addicted to turning pens.
Skie_M is offline   Reply With Quote Top
Old 02-02-2017, 01:56 PM   #4 (permalink)
edstreet's Avatar
Photos: 2
Kick the ebony to the curb and get you stabilized African Blackwood. It's higher quality wood, cheaper and easier to get and much easier to work with.
Anyone can COPY, it takes a *TRUE ARTIST* to CREATE
-- In times of universal deceit, telling the truth becomes a revolutionary act.
Design your own Polymer Clay Pen Blanks by Toni, Detailed 'CA' Article
edstreet is offline   Reply With Quote Top
Old 02-02-2017, 02:32 PM   #5 (permalink)
BeeAMaker's Avatar
Photos: 0
What if you left about 1/4" of the tube unglued in the blank. This way when you press the tip into the tube, that no glue zone may leave enough room for the tube to expand without putting to much stress on the wood. With no glue, there should be a hairline gap.
Just a thought
BeeAMaker is offline   Reply With Quote Top
Old 02-02-2017, 05:52 PM   #6 (permalink)
Photos: 0
Wow! Thanks for the suggestions! Very helpful. About the African Blackwood - It isn't as black as the ebony I've been getting. I'm looking for a glossy jet black effect for the pen. Is there jet black African Blackwood?
Old 02-02-2017, 06:25 PM   #7 (permalink)
duncsuss's Avatar
Photos: 1
Sand the components so they are a slip-fit into the tube ends and glue them in instead of press-fitting.
Duncan Suss
website: FruitOfTheLathe | facebook: FruitOfTheLathe
duncsuss is offline   Reply With Quote Top
Old 02-02-2017, 07:30 PM   #8 (permalink)
Ted iin Michigan's Avatar
Photos: 1
Yep - ebony has a (well deserved) rep for that. Stabilizing it one way or another is about the only way to lessen the threat.
FYI - some Blackwood will be "more black" than others. Plus it is quite a bit more oily than ebony. Needs to be wiped off with a solvent before finishing.
Might also take a look at Macassar ebony. Some of it is nearly as black as Gaboon ebony. But (I think) it behaves better.
Ted in Michigan
Go Buckeyes!
Ted iin Michigan is offline   Reply With Quote Top
Old 02-02-2017, 07:49 PM   #9 (permalink)
KenV's Avatar
Photos: 0
Much of the pen blank ebony is not dry. I have stock that has set for several years, and it only cracks where there were cracks in the dry wood.
Treat it as damp wood and the surprises go way way down.
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 02-02-2017, 08:33 PM   #10 (permalink)
jttheclockman's Avatar
Photos: 83
You will not get any deeper black than Gabon ebony. Yes there can be some slight streaks of gold in it but I have made pens with it and other projects using it and have not had any problems. If doing a pen I do soak the inside of the blank with thin CA. It is a very dusty wood though and will get into everything, so you need to be very good at clean up after each operation. Will take a shine and imperfections can be filled with thin CA and sanding dust very easily. I have had a stash for some time so I do know it is dry. Sorry none for sale
John T.
jttheclockman is offline   Reply With Quote Top
Related Content
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
