Drilling pen blanks - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 05-18-2017, 09:38 AM   #21 (permalink)
Woodchipper's Avatar
Photos: 1
Default
Quote:
When the tailstock has been extended as far as it can go and you have not gone completely through the blank - back out the bit without loosening the tailstock, stop the lathe, loosen the tailstock, move the bit forward into the blank, tighten the tail stock again, then start the lathe and start advancing the bit again. The longest blanks should only need to have the tailstock reset once ....
I brought up the same thing on another thread a couple of days ago. The quote is how I'm doing it with modifications suggest by others. I plan on practicing on scrap wood to get the best way to drill and have the hole the same size from one end to the other.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 05-18-2017, 03:03 PM   #22 (permalink)
needastick's Avatar
Photos: 2
Default Tailstock alignment
Hello Mark,
I'm a newbie and I'm reading this thread in order to glean some tips from the experienced turners.
I find drilling an accurate hole can be quite a challenge as there are so many possible variables.
One of those variables is tail alignment. Back in the day when I started to turn metal I made a simple jig to speed up re-setting the tail( after taper work) . This proved quite accurate for my standard of work.
http://www.penturners.org/forum/atta...1&d=1495133604
You will see that there is a very tiny hole drilled at the exact centre point. I made this by sliding the jig up to a rotating drill held in a small chuck. The jig can then be slid anywhere on the ways to confirm the tip of live centre will enter the hole.
The same would confirm the tip of your drill bit was centred, though not necessarily the back!
http://www.penturners.org/forum/atta...1&d=1495134033
The main use for this is for checking the height of cutting tools as you can see in the second pic.
An inexpensive project, may be of help to someone.
needastick is offline   Reply With Quote Top
Old 05-18-2017, 07:03 PM   #23 (permalink)
More4dan's Avatar
Photos: 5
Default
What material did you use for your centering jig?
More4dan is offline   Reply With Quote Top
Advertisement
Old 05-27-2017, 05:08 AM   #24 (permalink)
needastick's Avatar
Photos: 2
Default
I made the jig from 1/4"" brass sheet and some stable Teak stock. The wood hasn't moved and I machined it parallel and a tight fit to retain consistency.
Regards, Tony.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
