Drilling pen blanks - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 03-10-2017, 03:48 PM   #1 (permalink)
Photos: 0
Default Drilling pen blanks
Hi all. I'm hoping you can help me with a blank drilling problem I keep having.
I drill both wood and acrylic blanks using the bit sizes specified in the assembly instructions (from PSI). I drill with a Jacobs chuck on the lathe at around 500rpm and I back out the bit several times to remove scrap from the hole and the bit. When I dry fit the tubes, the drilled blank holes are always too big, forcing me to wrap the tubes in masking tape prior (to snug the fit) to gluing them in. Does this happen to other folks too or am I doing something wrong? Is masking tape a reasonable solution or should I be doing something else?
Thanks so much for helping out a fellow turner.
Mark
Markus666 is offline   Reply With Quote Top
Old 03-10-2017, 03:56 PM   #2 (permalink)
skiprat's Avatar
Photos: 227
Default
Welcome
Sounds like you have a tailstock alignment issue to me.
__________________
www.skiprat-pens.com
skiprat is offline   Reply With Quote Top
Old 03-10-2017, 04:01 PM   #3 (permalink)
mecompco's Avatar
Photos: 10
Default
Yup, somethings not right. I've only had that happen with one 12.5mm bit--replaced it and all is good. Now how oversize is the hole? I'm not thinking I'd trust the tape trick to last. I always use epoxy and you can goop enough in to fill holes that are slightly over-sized, as sometimes happens and all is good.
Regards,
Michael
mecompco is offline   Reply With Quote Top
Advertisement
Old 03-10-2017, 05:54 PM   #4 (permalink)
randyrls's Avatar
Photos: 68
Default
Quote:
Mark; I often find the sizes of drill bits that give me the best fit are NOT the ones on the instructions. The drill bits specified are the closest most common available size.
I have a 115 piece drill bit set and a 25 piece metric set. When starting on a new style/model, I drill a hole that is smaller than I think is correct. If the tube doesn't fit, step up to the next size larger until the tube just fits. Then write down that drill bit size on the instructions for the pen. There are several drill bit size charts in the Library.
Oh; added later, drill no more than 1/2" at a time.
Hope this helps...
__________________
Randy S.
I got my WHOLE BODY tattooed, but I didn't want to be conspicuous, so I had them use invisible ink. ---- Stephen Wright
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Old 03-10-2017, 06:08 PM   #5 (permalink)
Photos: 0
Default
I normally drill .010" over the measured tube size, this leaves room for paint and epoxy.
__________________
Jeff Miller
www.MillerTurnings.com
MillerTurnings is offline   Reply With Quote Top
Old 03-10-2017, 06:55 PM   #6 (permalink)
ALA
ALA's Avatar
Photos: 0
Default
A drill bit guide is very useful in this instance. Insert the tube into the guide for a reference. Of course, leave a little room for glue when selecting the bit.
ALA is offline   Reply With Quote Top
Old 03-10-2017, 07:29 PM   #7 (permalink)
mark james's Avatar
Photos: 484
Default
G'Day Mark,
All the suggestions above on drill sizes and drilling technique are all excellent. I can only add to combine those thoughts with the first suggestion posted by Skip... Check your Tailstock. Make sure your headstock and tailstock are in alignment, and that the tailstock is able to be tightened accurately. After that - yup, check your drill technique and the drill dimensions.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 03-10-2017, 08:58 PM   #8 (permalink)
Photos: 0
Default
If the bit shakes or moves from center while drilling then something is not aligned right as stated above. You should feel almost no vibration or movement of the drill bit and drill chuck when drilling.
__________________
Dale Allen is offline   Reply With Quote Top
Old 03-10-2017, 11:30 PM   #9 (permalink)
Photos: 1
Default
One thing to think about is when you back the bit out don't loosen the tailstock. I made the mistake early on of loosening the tailstock each time I backed out the bit and each time you do that there is a chance that it will not tighten in the exact location and this will cause the hole to widen.
When the tailstock has been extended as far as it can go and you have not gone completely through the blank - back out the bit without loosening the tailstock, stop the lathe, loosen the tailstock, move the bit forward into the blank, tighten the tail stock again, then start the lathe and start advancing the bit again. The longest blanks should only need to have the tailstock reset once ....
Hope that helps.
Bob Kardell is offline   Reply With Quote Top
Old 03-10-2017, 11:33 PM   #10 (permalink)
jttheclockman's Avatar
Photos: 83
Default
All good suggestions above. I will add also when you have the drill chuck in the tailstock, just snug up on the holding lever. And as you advance the drill bit hold the chuck with your left hand to steady it as it enters.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
