CLICK pen using Rollerball refill - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 08-10-2015, 04:31 AM   #1 (permalink)
Photos: 0
Default CLICK pen using Rollerball refill
I am looking for a CLICK pen KIT, using a Rollerball refill.
If a kit does not exists, then does any one have plans or specifications for a Click pen and its components that I could see if i can modify.
Commercially Pilot G2 provides this, but I have not found any in the handmade pen market.
thanks
Peter
Woodo is offline   Reply With Quote Top
Old 08-10-2015, 08:15 AM   #2 (permalink)
Dan Masshardt's Avatar
Photos: 0
Default
Generally rollerball refills need to be capped.
For your pride to you'd need to either find a special roller ink or use the g2.
There us mi stick kit. You'd have to modify something.
Dan Masshardt is offline   Reply With Quote Top
Old 08-10-2015, 08:20 AM   #3 (permalink)
thewishman's Avatar
Photos: 0
Default
Hi Peter, hewunch shared a great tutorial on this very topic. You can adapt it to any refill you want to use, just adjust the length and hole diameter to fit your needs:
http://content.penturners.org/librar...ssclickpen.pdf
__________________
Chris
Non Impedite Raditioni Cogitationis.
(Unencumbered by the thought process.)
Tom and Ray Magliozzi
thewishman is offline   Reply With Quote Top
Advertisement
Old 08-10-2015, 08:33 AM   #4 (permalink)
IAP Activities Manager
mredburn's Avatar
Photos: 83
Default
I have made them using an 8mm tube and the Schmidt CLick mechanism. A larger tube like the 3/8 would be easier. There was only one draw back to using the Schmidt mechanism and that was the travel of the refill. It works ok but it doesnt retract very far into the pen. Meaning that pocket lint or shirt material etc coming in contact with the refill tip led to a very big mess quickly. perhaps some of the other mechanisms from a kit may work better.
Because part of the roller ball experience is the spring in the back which gives the refill a cushion when writing I ended up using a reg roller ball spring in the back and a regular ball point spring in the front.
All the best
__________________
Life occasionally offers us the opportunity to make very very hard choices. I have had such offers.
Level 6 Pen Wizard, smoke, mirror and sleight of hand enabled.
Mike.
http://www.silverpenparts.com
mredburn is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
click pen , pilot g2 , plans , rollerball , specifications
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
