CA finish chipping - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 11-27-2017, 02:40 PM   #1 (permalink)
Photos: 0
Default CA finish chipping
I have just about conquered CA for my pens. I have been successful with the final gloss and the ability to separate them from the bushings with out damage.
Now I am finding that there is often a slight separation of the finish from the blank that happens when I press the parts into the blank. I have tried to touch the s[pots up with some thin CA but if I'm not perfectly steady the the finish at that spot is compromised.
What do others of you do to avoid this happening? It might also be only happening on oily woods. The pic is from a cocobolo blank.
DB in VT is offline   Reply With Quote Top
Old 11-27-2017, 02:54 PM   #2 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I find that there might be a bit of CA raised above the blank. I lightly apply the end of the blank to fine sandpaper and lightly rub in a circular motion. Remember- lightly!
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 11-27-2017, 03:09 PM   #3 (permalink)
Photos: 12
Default
I agree with John's assessment. For my finishing process I apply CA then sand/polish and then apply CA again before final sanding/polishing. After the first application of CA I will sand the ends lightly with 400 grit, after the final polishing I will sand the ends with 2000 grit.
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Advertisement
Old 11-27-2017, 04:34 PM   #4 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Lifting happens on occasion for some and more for others on oily wood and bushings; or on oily wood during assembly. This very problem was what pushed me to TBC 10 years ago. I had access to a good bit of oily ebony and the lifting showed. You ďcanĒ try rubbing oily wood down with acetone before applying CA, but that doesnít always help.
TBC eliminates the bushing problem. While lifting may not occur in separating from the bushings, the stress caused in breaking away will lead to sensitivity to lifting during assembly. Over pressing alone can cause the lifting, but the stress caused in separation adds to it.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 11-27-2017, 05:08 PM   #5 (permalink)
Photos: 0
Default
I have been doing quite a bit of cocobolo lately and that's why I wondered if it might be an oily wood issue. My normal technique is to very carefully carve a SLIGHT chamfer around the end with a razor knife. I feel more comfortable with that than slipping with a piece of sand paper, although I have used sand paper at times.
And this only started happening over the last few weeks. My shop is in my basement and has gotten colder due to the change in the weather. Maybe the CA is more brittle at lower temperatures.
I will pay more attention to the sanding technique.
Also, what is TBC? If it stands for 'turn between center' then I'm already doing that for almost everything.
Old 11-27-2017, 05:50 PM   #6 (permalink)
Photos: 0
Default
I've also found that sometimes that if i put too much "wax" on bushing to reduce separation issues it can cause lifting problems at the ends.
duanechun is offline   Reply With Quote Top
Old 11-27-2017, 06:36 PM   #7 (permalink)
More4dan's Avatar
Photos: 5
Default
Iíve switched to HDPE bushings when applying CA Then lightly sand the ends with 500 when finish polishing.
More4dan is offline   Reply With Quote Top
Old 11-27-2017, 06:56 PM   #8 (permalink)
Photos: 0
Default
After 5 to 10 coats remove and sand ends flat. lessens the buildup.
wouldentu2? is offline   Reply With Quote Top
Old 11-27-2017, 07:30 PM   #9 (permalink)
Photos: 12
Default
TBC eliminates a lot of problems, I switched and haven't looked back. Here's the tutorial I learned from: http://content.penturners.org/librar...en_centers.pdf
__________________
--Sam
Old 11-27-2017, 09:03 PM   #10 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
When I first replied, I was out (in the car waiting on LOML) and viewing the thread on my cell phone. Now that I see specifically the problem, there could be 2 causes: 1. wood not flush with the tube or 2. too much pressure during assembly or both. "Technique" learned from experience should cure it.
CA does not like assembly pressure other than just adhering to the wood.
__________________
Hank Lee
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
