Anti Seize Lube - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Welcome to penturners.org! > Site Help, Tips, How-To
  Forgot Password
Site Help, Tips, How-To Get and give help for using the FORUM SOFTWARE.
Reply
Old 10-09-2018, 10:15 PM   #1 (permalink)
WriteON's Avatar
Photos: 0
Default Anti Seize Lube
Nova chucks call for anti seize lube on the screws that secure the jaws. I'm seeing different types of lube...copper, aluminum. What specific type is used...or do you not use it at all. Thanks, frank
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool professional pool cue repair lathe
WriteON is offline   Reply With Quote Top
Old 10-09-2018, 11:08 PM   #2 (permalink)
Photos: 43
Default
Teknatool mentions Rocol J166 which is a copper / molybdenum / graphite anti-sieze. But they also mention grease or oil.
I use oneway chucks and I just use grease or bowling alley wax (I keep a can in the shop for all sorts of uses) every now and then on the screws. If I was going to be heating the chucks to over a thousand degrees I would probably use anti-sieze, but I'm not and I don't. The chucks are going on 15 years old and I haven't had a problem.
Ed
Ed McDonnell is offline   Reply With Quote Top
Old 10-09-2018, 11:15 PM   #3 (permalink)
gtriever's Avatar
Photos: 3
Default
I haven't used it on the lathe, but I have used it in the past for stainless to stainless hardware to prevent thread galling. The specific one we used was Permatex Nickel.
gtriever is online now   Reply With Quote Top
Advertisement
Old 10-09-2018, 11:16 PM   #4 (permalink)
Photos: 0
Default
G'day Frank. In my case, the answer is "not used at all". I live near the coast with a lot of salt air, and have never had a problem with the retaining screws when changing the jaws.
Have just changed one set of jaws after 6 years and the screws came undone easily.
Cheers, Gary H
Gary H is offline   Reply With Quote Top
Old 10-10-2018, 08:05 AM   #5 (permalink)
WriteON's Avatar
Photos: 0
Default
Thanks for the replies. I will pass on the anti.
__________________
Current set up:
Jet 1221VS
Old 10-10-2018, 08:40 AM   #6 (permalink)
TonyL's Avatar
Photos: 6
Default
Never even knew there were instructions to do anything. Thank you for the post.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 10-10-2018, 09:04 AM   #7 (permalink)
gtriever's Avatar
Photos: 3
Default
As a side note, if I use any kind of lube around the lathe, it's a Dry Lube unless there's a specific need for some type of grease.
Old 10-16-2018, 10:35 AM   #8 (permalink)
WriteON's Avatar
Photos: 0
Default
Same value different item. Do we use anti seize lube or plumbers grease for garden hose to keep the pistol from binding. Those things stick like electronic magnets.
__________________
Current set up:
Jet 1221VS
Old 10-16-2018, 10:50 AM   #9 (permalink)
gtriever's Avatar
Photos: 3
Default
In that case, you'd use a grease.
Old 10-16-2018, 11:21 AM   #10 (permalink)
WriteON's Avatar
Photos: 0
Default
Quote:
__________________
Current set up:
Jet 1221VS
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
