What do I need to know for BP nib/tip? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 03-16-2017, 10:23 AM   #1 (permalink)
Photos: 0
Default What do I need to know for BP nib/tip?
I'm looking at making a kitless BP pen (not fountain pen). I've searched and searched and there is a lot of information on making the body parts but, I can only find fountain pen section/nib info and nothing for BP or roller tips. I'm not even sure if these are correctly called tips or nibs.
Is there anything I need to know as far as internal tip dimensions? Does it just need room for whatever refill I'm going to use?
Initially just going to make one with screw cap and no twist or click mechanism. But, if I do make those kind, is there anything special about the tips internally?
I guess this is a long way of asking how to make a tip for BP pen!!!
Thanks,
Regis
RegisG is offline   Reply With Quote Top
Old 03-16-2017, 11:48 AM   #2 (permalink)
KenV's Avatar
Photos: 0
Default
Regis
Ball point nibs and internal specs can be found with the articles on using bullets in shell casing pens. Two specs for drilling are used. One for cross style refills and one for parker style refills
Don Wards book also covers the topic well.
The outside shape is a matter of artistic design and materials choice --tempered by skills and capability.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 03-16-2017, 11:58 AM   #3 (permalink)
Photos: 0
Default
Quote:
Originally Posted by KenV View Post
Regis
Thank you KenV.
Advertisement
Old 03-16-2017, 12:02 PM   #4 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Your ink refill is your home base. It is a fixed dimension....the rest, you build around it.
A pair of calipers, a collet chuck a huge box of drill bits will be your friends...and taps and dies. Use an existing kit ball point/rollerball pen as a basis for measurements.
Good Luck!
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 03-16-2017, 12:24 PM   #5 (permalink)
Photos: 0
Default
Good Luck!
Thank you Charlie_W. I do have a metal lathe also and lots of drill bits....
The kits I currently have are twist, so that mechanism holds the refill and the inside of tip doesn't matter as long as tip will protrude. But, your point is well taken and that perhaps is what I should do first, make one for twist mechanism.
Regis
Old 03-16-2017, 12:56 PM   #6 (permalink)
IAP Activities Manager
mredburn's Avatar
Photos: 83
Default
Assemble the tranny and its connector if you are using that to make your pen. (parker style refill) Put the refill in the tranny and extend it aall the way out. Measure from the base of the threaded connector to the tip where you want the Nose cone to end.
The nosecone will not only need to be drilled for the refill, but also for a place to set the spring. I use a #37 or#38 drill bit for the tip, a D drill bit for the refill, although a 1/4 will work. and a #19 (11/32 will work also) for the spring. You will need to measure the diameter of your spring to determine which drill size works best.
__________________
Life occasionally offers us the opportunity to make very very hard choices. I have had such offers.
Level 6 Pen Wizard, smoke, mirror and sleight of hand enabled.
Mike.
http://www.silverpenparts.com
mredburn is offline   Reply With Quote Top
Old 03-16-2017, 01:27 PM   #7 (permalink)
duncsuss's Avatar
Photos: 1
Default
Kurt Hertzog has written several articles which might be a good read to give you background -- an index is at LINK
Here's "making a stick pen" ... LINK
And here is "swap out the standard nib and cap" ... LINK (I think this one covers exactly what you are hoping to do)
__________________
Duncan Suss
website: FruitOfTheLathe | facebook: FruitOfTheLathe
duncsuss is online now   Reply With Quote Top
Old 03-16-2017, 02:47 PM   #8 (permalink)
Photos: 0
Default
GREAT articles!!!
Thank you,
Regis
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
