What bandsaw to choose from.
jxdubbs
Derry NH USA
Hi,
I've been looking to buy my first bandsaw. I'm making pens for the most part, but as well as other woodworking projects like bowls, cutting boards Ect.
So I have around $300 to spend. I've been researching for a few weeks. The ones I like the most would be...
WEN 3962 10-Inch Two-Speed Band Saw with Stand and Worklight
OR
RIKON 10" Bench Top Bandsaw, Model 10-305
https://www.rikontools.com/product/10-305
Honorable Mentions...
GRIZZLY-G0803 - 9" Benchtop Bandsaw
9" Benchtop Bandsaw | Grizzly Industrial
Thank you for all your wonderful help. I've looking forward and exited to what you have to say about these band saws.
James
Sent from my SM-G930V using Tapatalk
tonylumps
newtown square pa
I have the Wen that you are showing.Had it for almost 2 years as long as you know it's limitations go for it. It is easy to adjust the guides and install blades i keep a Bi-metal blade on it for almost everything I cut all of my blanks and tubes. 2 things you do not want to cut are Stone Blanks and Seashell. If I want to cut something large than I switch to a 1/2 blade You can,t beat the price. Now if you are going to resaw large logs forget it
Lenny
Searsport, Maine
Those may suit your needs, however my advice would be to consider waiting until you can afford to buy a 14" saw. If you just don't have the space, I would say go for the Rikon as their support is some of the best.
Penultimate
Bartlett, IL 60103
The latest issue of Wood magazine has a bandsaw review. The Craftsman 14 inch (a Rikon, I think) got the best tool award. The Rikon got the best ten inch saw.
I have the Craftsman Rikon and it works well, I recommend it. But consider this., if you mount a ten inch saw on its own stand you take up about the same room as a 14 inch saw.
Good luck, have fun.
Lenny
Searsport, Maine
I actually have the Craftsman 14" as a second bandsaw. It is exactly the same saw as the old Rikon 10-321. My other saw is a 2hp 17" Grizzly GO513X2F
I use the Craftsman in my basement turning area and bought it because 1. I didn't want to spend a lot and 2. It does more than I need.
Given that so many Sears stores are closing, there may be some bargains to be found.
acturbo
Wilmington, DE
I will second this. I have a 10" craftsman in my shop and am currently looking for 14" or larger. Especially if you are planning on doing bowls cups etc a 10" or less is going to need upgrade sooner rather than later.
I search craigslist everyday and if I don't find anything I'm going after the 14" Rikon that goes for around $799 after I save enough.
Bikerdad
Utah Valley
Wait, and purchase a used 14" bandsaw. The last good small bandsaw was made by Inca, a company that has been out of the North American market for some time. The only strong use case I can see for one of the wee bandsaws is if one absolutely can't find the space for a larger bandsaw. I can usually find half a dozen used 14" Delta clones available here any given month, with a least a couple of them under your $300 target.
Heck, I'm going to be selling my 14" Delta Delta clone sometime this year when I upgrade.
