Using Pin Chucks - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 05-30-2017, 12:19 PM   #1 (permalink)
Photos: 0
Default Using Pin Chucks
I spent some time over the weekend delving into the world of kitless and closed end pens. One issue I ran into is getting the drilled blank to turn true on the pin chuck - I keep getting a wobble. The blank is well seated on the pin and it turns fine, but results in a slightly out-of-round condition. Is there a trick to mounting the blank on the pin chucks?
__________________
"The quality of a person's life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor."
Vince Lombardi
bjbear76 is offline   Reply With Quote Top
Old 05-30-2017, 12:24 PM   #2 (permalink)
duncsuss's Avatar
Photos: 1
Default
Does the pin have any runout before you slide the barrel onto it?
__________________
Duncan Suss
website: FruitOfTheLathe | facebook: FruitOfTheLathe
duncsuss is offline   Reply With Quote Top
Old 05-30-2017, 12:34 PM   #3 (permalink)
Photos: 0
Default
Quote:
No, it seems like the blank is not perefectly parallel with the pin.
__________________
Vince Lombardi
Advertisement
Old 05-30-2017, 12:40 PM   #4 (permalink)
Photos: 1
Default
Do you have a dial indicator that you can zero on the pin chuck and turn the chuck by hand? To see if there is any wobble?
__________________
John
Carbide turning tools and replacement inserts.
www.ncwoodturningtools.com
or
find me in the Vendors Forum.
http://www.penturners.org/forum/f389/
hanau is online now   Reply With Quote Top
Old 05-30-2017, 12:46 PM   #5 (permalink)
Photos: 0
Default
Quote:
yes, I'll check that tonight
__________________
Vince Lombardi
Old 05-30-2017, 12:51 PM   #6 (permalink)
KenV's Avatar
Photos: 0
Default
Bill,
I HAD one pin chuck that was a loose sloppy fit into the brass tube. The slop allowed the tube to skew to the side enough to be a problem. I could compensate with shim stock, but the hassle was not worth the replacement cost, and got an expansion style to replace it.
If there is not slop inside the tube, time for a dial indicator and careful checking.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 05-30-2017, 01:03 PM   #7 (permalink)
Photos: 0
Default
Maybe I should clarify a bit. I'm turning an ebonite blank for the cap end of a fountain pen. I've drilled up to 1/2" of the closed end of the blank. Since there's no brass tube, is it possible the pin is causing the blank to skew a bit when it "grabs" in the flat of the rod?
__________________
Vince Lombardi
Old 05-30-2017, 02:21 PM   #8 (permalink)
Photos: 7
Default
Might be digging into the wood which would deform it.
37
__________________
100 years from now, will it matter?
38
tjseagrove is offline   Reply With Quote Top
Old 05-30-2017, 02:40 PM   #9 (permalink)
duncsuss's Avatar
Photos: 1
Default
Quote:
How tight is the rod when you're pushing it into the blank?
The ones that Rick Herrell made for me were a perfect fit, and it was a struggle to get them into the hole because they were acting like a piston in a closed cylinder. (He machined a small groove in the next ones he made for me, to act as a pressure relief )
If you can push the blank onto the rod with no effort, it's too loose, and you will get some twist when the pin locks in place.
__________________
Duncan Suss
Old 05-30-2017, 03:27 PM   #10 (permalink)
Photos: 14
Default
I use pin chucks very often. I would say two things:
First, if the piece is on the chuck without pin and if I pull it suddenly off, I want to hear a "ploc", something like the sweet noise of a cork out of a wine bottle. If not, the pin may hold it tight, but it will be out of center.
Second, a pin chuck is great for finishing/sanding, not too bad for very light final turning, but very clumsy for roughing. So I use the tail stock as long as possible, which mean a little extra-length ebonite I turn out at the end.
Hope it helps.
__________________
Pierre
Kit less, create more.
Pierre--- is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
