Twisted tutorial/photo journal - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 10-24-2015, 09:06 PM   #1 (permalink)
Spanx's Avatar
Photos: 54
Default Twisted tutorial/photo journal
Hi everyone,I photographed my way through a twisted pen design.For those of you that want to give it a go I hope you can find this usefull.
I started with a 1 1/2 x 1 1/2 x 9 spindle blank.I thought it was Bocote.1.jpg
Turn to a cylinder and then layout 4 sets of points r1/4" with a compass.
I did one end,useing the tool rest as a guide I drew a line across the length and transferred the points on the opposite end.
This part can be distegarded if you have the right jaws.I initally turned the blank to a cylynder with tenons on both ends.I did this because my #2 jaws were too big and I didn't want to over extend my pin jaws.When I went to set the outer points the wood started to split so I had to make reinforcement collars and just have to deal with the jaws the way they are.2.jpg
After trueing the collars up I parted the blank where I wanted the lengths of the body and cap.3.jpg
Remount the blanks for drilling 3/8" x 2" for the body.27/64" x 2" for the cap.4.jpg
I made a double sided tenon a little over 4".Using a dial caliper make each side just a little big and then sand it down so that it fits very snug.If it is a little long just trim the tenon a little bit.6.jpg
After both sides are done reassemble the cylinder with the tenon inside.7.jpg
Trasnfer the lines to the end and number them 1-4.Offset the numbers on the opposite end.8.jpg
Press all the point sets in.You may need to predrill them a little bit on really hard wood.Mount the cylinder between one set of points and lets get started.9.jpg
I turned at full speed, 3300rpm.Looks kinda weird with all that airwood spinning around.10.jpg
I got out a measuring stick and marked it.I will use this mark through all the point sets.12.jpg
Remove the cylinder from the lathe,slide the halves apart and check the wall thickness.19.jpg
I wanted the walls to be thinner so I remounted the cylinder and ran through the point sets a second and third time.20.jpg
Once satisfied about size I remounted the blank on true centers and sand out any tool marks with 220g.Part off the ends.21.jpg
Time to clean up the ends.Remove either the cap or body and remount it into the chuck by the tenon and now clean up the end.22.jpg
Remove the tenon and do the other half same as the first.Remove from the tenon and set aside.23.jpg
Remound the tenon by the small end and drill out the large end with a 7/64" bit as far as it will go.24.jpg25.jpg
Remove the tenon and layout all the parts including the refill.Place the refill in the body.With the tenon placed next to the body and refill mark where the shoulder of the refill will be on the tenon.26.jpg
As you can see the tenon is too long for me to drill so I will mark it again where I will part the excess off.27.jpg
Remount the tenon by the large end.After parting off the excess I drilled to the depth marked on the 15/64" bit.28.jpg
Remount the tenon by the small side.Shape,trim and sand what is now the front section.Testing the fit as you go.30.jpg
Spanx is offline   Reply With Quote Top
Old 10-24-2015, 09:28 PM   #2 (permalink)
Jim15's Avatar
Photos: 66
Default
Thank you for sharing, very interesting.
__________________
jim,
Hamilton, Ohio
Jim15 is online now   Reply With Quote Top
Old 10-24-2015, 09:33 PM   #3 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Dale,
Nice job on the write up and the pics!
A while back, I turned a 4 sided twisted cherry cup.
These are good skill building projects!
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Advertisement
Old 10-24-2015, 10:29 PM   #4 (permalink)
Spanx's Avatar
Photos: 54
Default
Ran out of editing time.
Assemble the section to the body,press on the tip of the refill to test for any front to back movement.32.jpg
If there is remount the section in the chuch leaving the shoulder exposed.Trim a little off at a time and retest the fit.33.jpg
Assemble all the parts.If there is any finessing of the fit that needs to be done,it can be done by either sanding the inside of the cap and/or body if it's too tight.If it's too loose you can apply CA with a Qtip to the inside of the cap and/or body.
Now I can finish sanding the outside of the pen.It has to be done fully assembled or I will not be able to blen the seam together.I use 220,320,and 400gsand paper.34.jpg35.jpg
Fininshing can be done a number of ways.I've done a buff and wax method and I've also done a shellac and wax finish.This time I will do a laquer finish,I will post it in SOYP whe I have it completed.
I hope this tutorial is of use to you or at least interesting.
Best wishes, Dale
Old 10-24-2015, 10:31 PM   #5 (permalink)
magpens's Avatar
Photos: 67
Default
Thanks, Dale !! . I really appreciate you doing this for us !!
I was one of the people that asked for it. . I intend to study the procedure and give it a try ... in due course.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 10-24-2015, 10:45 PM   #6 (permalink)
magpens's Avatar
Photos: 67
Default
Am I correct in deducing that to replace the refill you remove the tenon piece ?
__________________
Mal
Old 10-25-2015, 08:16 AM   #7 (permalink)
Spanx's Avatar
Photos: 54
Default
Thanks Jim, Charlie ans Mal.
Mal, yes, to replace the refill pull the tenon/section from the body.
Old 10-25-2015, 09:25 AM   #8 (permalink)
Charlie69's Avatar
Photos: 11
Default
That's wild man. Nice job on the tutorial, clear, concise, easy to understand & great photos. Heck of a lathe too
__________________
Jet 1014 non-vs
Charlie69 is offline   Reply With Quote Top
Old 10-25-2015, 09:48 AM   #9 (permalink)
OKLAHOMAN's Avatar
Photos: 105
Default
Thanks, now that's thinking outside the box.
__________________
Now I'm just one of the Guys. If your looking for the best merchandise at the best price's and service visit Niels and Debbie at
WWW.CLASSICNIB.COM
OKLAHOMAN is offline   Reply With Quote Top
Old 10-25-2015, 12:28 PM   #10 (permalink)
Spanx's Avatar
Photos: 54
Default
Thanks Charlie and Roy.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
