Thread size for Parker pencil mechanism?
duncsuss
Wilmington, MA
I am trying to figure the right tap for the Parker Style Pencil Mechanism - 0.5mm:
https://www.beartoothwoods.com/catalog/product_info.php?products_id=4996
It's very close to 7/32 - 32 but not quite it. I am not versed in tap and die sizing and need some help. I am thinking an m5.5 or m6 x .5 tap might be the proper tap. Any help would be greatly appreciated.
I haven't tried making any of these, so I can't offer an answer -- but have you asked Bear Tooth Woods?
Cwalker935
Richmond, Va
They did not know.
bmachin
Owensboro, KY
32 tpi is not close to .5mm. It is much closer to .8mm. (1/32"=.793mm). (.5mm=.020"). (.75mm=.030")
Sorry, but it's the only help that I can offer. You might take these numbers to victornet.com and check their taps to see if they have any metreic taps that appear close.
Bill
magpens
Canada
I trust your word, Cody, but reading your reference to 7-32 caused me some surprise. I looked up the clearance hole size for that and find it to be something like 0.16", if I am interpolating the reference table correctly. That is quite a bit smaller than the 5.75mm (0.226") size of the thread stated by Milan.
Even a 7-32 tap is "non-standard". But Victornet does have them and I bought a couple for a special purpose I have related to using the click mechanism out of a Slimline Pro to make a so-called "kitless" pen. Turns out that the "stub" of that click mechanism is threaded 7-32 for screwing on a pushbutton.
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Haven't measured that one, but attached is a concept I have used many times. Measure the OD over the threads and size the tap just a little larger. Take a picture of the threads next to a steel rule, blow up the picture and count a number of threads that comes close to lines on the rule. Do some calculations, and it should work. The attached was from a Pentel Pencil nib and bought the taps on EBay.
  • thread measuring.pdf
Cwalker935
Richmond, Va
The OD of the threads is exactly 7/32 or around 5.6 mm, using Bruces's thread counting method I get .75 mm or 34 tpi. Given that the Milan's pens info seems to be right. That solves one problem but raises another- where to find a m5.75 x .75 tap. I am not having any luck finding one and wonder if a m6 x .75 would work. Any thoughts?
Thanks for all the help.
