Single thread or musti start? - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 04-23-2008, 04:52 PM   #11 (permalink)
Dan_F's Avatar
Photos: 0
Default
Well, between the fact that the general opinion is they are not very sturdy and are difficult to sell, the outlook isn't exactly encouraging.:D
At this point I'm just considering options. I have one of the multi thread tap and die sets coming from the group buy, but would like not to be limited to El Grande sections.
I'm thinking about a mini metal lathe, but can't find much in the way of info on cutting MS threads with it. I have no experience with such things.
Dan
__________________
"Blaming others is like having an itch on your butt and scratching your head"
-Ajahn Cha-
http://i98.photobucket.com/albums/l2...DSC_0334_2.jpg
Dan_F is offline   Reply With Quote Top
Old 04-23-2008, 05:14 PM   #12 (permalink)
Photos: 45
Default
Quote:
Originally posted by Dan_F
... I have one of the multi thread tap and die sets coming from the group buy, but would like not to be limited to El Grande sections...
Hi Dan, Either I am misunderstanding you or you are misunderstanding what you can do with your new tap and die set.
For starters, the threads the tap and die set will make are indeed the same as the threads on an El-Grande pen kit but that's where the similarity can end. Many pen makers chose this particular thread because th El-Grande is a popular pen to modify. This DOES NOT mean that you have to make El-Grande compatible pens or use any El-Grande kit parts when using this tap and die set.
I have made a few dozen different pens whose threads have been cut with the tap and die set mentioned and if you've noticed any photos I have posted lately, none of them come close to an El-Grande! I start with an acrylic blank, do some drilling and tapping, a little notching here and there, grab some silver stock and add a center band and an accent ring or two, add a clip and call it a pen!
You are free to design any kind of pen you want. The only constraints you have using a tap and die is that the cap and body diameters must accommodating the threads.
__________________
No longer a participating forum member
Texatdurango is offline   Reply With Quote Top
Old 04-23-2008, 05:15 PM   #13 (permalink)
PenWorks's Avatar
Photos: 16
Default
Dan, I wouldn't be so down either. I made these single thread designs well over 3 years ago and they work just fine. The black one closes in one turn and the red one takes two turns. As for collectors. I have never sold a pen to a collector that has asked if it is a multi start thread [:0] They either like how the cap screws on or they don't. I say go for it, these were just cut with a standard fine tap & die set, nothin fancy.
__________________
Anthony
The Golden Nib - Specialty Supplies for turners. Pen kits, refills, gold nibs, shaving supplies, Scottsdale, AZ
Penchetta Pen & Knife - Retailer of fine writing instruments, Scottsdale, AZ
PenWorks is offline   Reply With Quote Top
Advertisement
Old 04-23-2008, 07:54 PM   #14 (permalink)
Photos: 1
Default
OOOOps, I deleted my previous message when the power went off in the middle of revising it. Here it is again with some additional comment.
It is all a matter of the shear strength of the threaded parts. The more threads engaged the higher the shrear strength of the thread. 5 full threads is a commonly used rule for thread design. Most pens have somewhere between 4 and 5 full threads engaged when the cap is on the pen.
A pen cap that requires less than 2 full turns to screw it on the pen is a lot more "user friendly" than one that requires 5 turns to accomplish the same thing.
A single thread with only 2 or 3 threads will be a weaker thread, and more likely to be damaged.
Then, as Lou said, the steeper lead angle of the multi-lead thread also requires less effort to screw on and off and break the seal when it is removed.
There is also the matter of "tradition" for fountain pens. Like pens with caps that don't post, it is all but impossible to sell a pen without a multiple-lead thread and something close to 5 full threads between the pen and its cap. Most buyers don't like things that are different from what they are used to seeing. However, you will find this preference will be different in different markets, if you are selling pens.
We can use any size and number of threads we want if we are our own customer. We will have to alter our design to meet the needs of someone else if they are the custopmer
Having said all of this, the bottom line is - it has nothing to do with the thread size, how many threads are engaged, or how many twists it takes to put the cap on the pen. Within reasonable limits. if it works, stays on, and doesn't wear out, the customer will like it and buy it, even if it doesn't have any threads at all. Yes, there is a case to be made for the "slip fit" cap.
"Reasonable limits" would dictate that I don't use a 1/2" coarse thread, but I might be inclined to use one of the fine or extra-fine thread series taps and dies for cap threads. Quite often, a metric thread is better suited, and again, taps and dies are available.
And, don't give up on the ElGrande tap and die set. It can be used for a lot more than duplicating the cap threads on an ElGrande. I would not be surprized if you couldn't make a postable cap for a Baron with these threads. Or, you can design your own pen, and forget about the kit.
__________________
Russ Fairfield
Post Falls, Idaho
Visit my Website for instructions on making a pen
http://www.woodturner-russ.com/Pen10.html
RussFairfield is offline   Reply With Quote Top
Old 04-23-2008, 10:11 PM   #15 (permalink)
PenWorks's Avatar
Photos: 16
Default
Another way to look at single lead threads, the Michel Perchin rep was in today. I was foundling the new Limited Edition Red Cross pen, retail around $4,500.00 As I was unscrewing the cap, which I was doing very slowly, turning, turning & turning seemed to go on forever...........:)
As if you were slowly unwraping a present you knew would be amazing once you opened it.
Sometimes, that is how a fine pen should be, why are we always in a hurry. Like fine wine, most of us don't beer bong a $100.00 bottle of wine :D
$4,500.00 pen, single lead thread, I would say it is a collectable pen [8D]
__________________
Anthony
Old 04-23-2008, 11:35 PM   #16 (permalink)
Photos: 1
Default
I think we are getting back to one of Dan F's concerns expressed in his original post. That being "fancy (expensive) taps and dies" but now we are talking about single start taps and dies.
I looked at the pen that Anthony mentioned. It looks like a one lead and pitch thread at about maybe 25% depth. That would difinately be a special order item.
The el Grande tap and dies are 12mm x 0.8 three start. A 12mm x .8 single start would also be a special order item as far as I know. That size would translate to about a 1/2 inch x 32 tap and die which again would again be custom. Some of you may know where to get these special sizes off the shelf and I would like to know where they are located:)
Chuckie
__________________
Chuck Key is offline   Reply With Quote Top
Old 04-24-2008, 06:32 PM   #17 (permalink)
Dan_F's Avatar
Photos: 0
Default
OK, I guess the news is out, I do get a bit confused form time to time.[:0]. I keep associating the tap and die set with the section instead of the cap.
My initial post was born of the the frustration of dealing with a four start thread set for a Little Havana kit, on which I wanted to have the blank line up in a certain way. Since this is a pen that virtually requires the cap to be posted for use, as the body is so short, it needs to align correctly when capped as well as when posted, or the clip will digging into the hand when writing. That makes is necessary to remember two sets of landmarks to start the threads for closing or capping the pen. Multiply this by a hand full of pens, and that's a lot to remember, particularly for one who is prone to "senior moments"
So if there was a cheaper, simpler way of doing things, that would be good as far as I'm concerned. I would love to see some ideas on friction or snap fit caps too, as that's the direction I'd rather move in.
Anthony---What size of tap and die set did you use for the pens you posted?
Texatdurango---Yes, I have seen your pens, and in spite of that, for some reason my brain simply reverts to following the pattern of the kits. Just force of habit I guess. Thanks for reminding me.
Russ---Thanks for clarifying your previous post. I would like to come up with something like a closed end Little Havana, with beefy, non coved, similarly weighted section, but a much lighter friction fit cap. I would think that this could be made to balance reasonably well with the cap posted. I'm not a fan of feather weight pens, though find the full sized CSUSA pens such as the Gent a bit too heavy. In fact, I 'm not completely happy with any of the FP kits I've done, between issues of weight, balance, comfort of section, and nib.
Well enough rambling, thanks again to all who have contributed.
Dan
__________________
-Ajahn Cha-
Old 04-24-2008, 07:05 PM   #18 (permalink)
bitshird's Avatar
Photos: 61
Default
Quote:
Chuckie
Chuckie; MSC has 1/2-32 in an H3, they also offer a 12 x.5 pitch, I'm not to up on DIN class but it was D6 so it's probably a bout the same as our class 3, prices weren't that bad,
__________________
Ken Ferrell
Maker of the world famous Woodchuck Pen Pro
"Sharper-Faster- Easier
bitshird is offline   Reply With Quote Top
Old 04-24-2008, 07:48 PM   #19 (permalink)
Photos: 1
Default
Excellent! Thanks. I found out Victor Machine also has a good selection also including a 7/16 x 64 tpi. Can you imagine, put just 1/8th inch of threads on the cap and it would take eight turns to tighten the cap :D
Chuckie
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
