Realistic Cigar SNAFU.. Please help:( - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 02-27-2017, 06:25 PM   #1 (permalink)
Flush1974's Avatar
Photos: 38
Default Realistic Cigar SNAFU.. Please help:(
Well by dumb luck my first one turned out pretty good, and since then everything has gone wrong. I can't seem to drill either a straight hole or a proper hole, NONE of my pens are lining up properly. I have followed the instructions that Wood Butcher so graciously made, and still my pens only fit right when twisted on only one way. You have to line up the threads just right or it becomes off round.
I am using:
Rikon 12-16 lathe
60 degree live tail
4 Prong Drive center
Heavy Duty 1/2" Keyed Lathe Drill Chuck #2 MT
or E32 Collet
I round the blank, part it with a parting tool on the lathe. Then I find the center of the two halves with a Robert Larson 800-2875 Plastic Center Finder and use either a collet I just purchased or a 4 Jaw Lathe chuck and drill the appropriate holes. I follow the rest of the instructions and this is what I get 9 out of 10 times.
Man..... I've tried everything, bought every tool I can think of to fix this. I'm just tired of wasting nice wood. Any help would be greatly appreciated!!!!!
This is what it looks like when the right thread of the triple start is lined up propperly.
View in gallery
This is what it looks like when it's not.
View in gallery
View in gallery
View in gallery
View in gallery
Lined up propperly.
View in gallery
Not so much.
View in gallery
View in gallery
View in gallery
View in gallery
View in gallery
View in gallery
View in gallery
View in gallery
Thanks for looking. Please help me unjack my universe.
Flush1974 is offline   Reply With Quote Top
Old 02-27-2017, 06:37 PM   #2 (permalink)
Mr Vic's Avatar
Photos: 2
Default
Could be one or the other or both are off center/out of round. How are you turning the two sections?
__________________
Mr Vic
Keep the shiny side up and the greasy side down.......
President Pikes Peak Woodturners - AAW Chapter
Mr Vic is offline   Reply With Quote Top
Old 02-27-2017, 06:54 PM   #3 (permalink)
Flush1974's Avatar
Photos: 38
Default
Quote:
I glue the Buckeye and the wood of choice together into about a 6.5" blank. Mark the center of each end and turn it as one piece. Once it's round I part it to the proper length per the instructions from Wood Butcher.
Advertisement
Old 02-27-2017, 07:10 PM   #4 (permalink)
Mr Vic's Avatar
Photos: 2
Default
Pulled up the instructions. If you were turning on a mandrel I'd say it was bent or you had out of round bushings. Are your head and tail stock aligned? Off a bit could make the pen a bit elliptical. If you have calipers available try check the pen to see if it is truly round. Just kind of tossing some ideas out. Never tried one but now may have to.
__________________
Mr Vic
Old 02-27-2017, 07:50 PM   #5 (permalink)
its_virgil's Avatar
Photos: 74
Default
The threads spear to be multiple start threads so the cap must be started at only place to align the way you want...double, triple, or quad start threads.
As for out of round there are several causes. Sending is often ignored but sanding can cause perfectly round pen barrels to become out if round because of the grain o opposite sides of the pen barrel.
Do a good turn daily!
Don
__________________
Don Ward aka its_virgil
Wichita Falls, Texas
www.RedRiverPens.com
www.RedRiverPens.com/articles (pen stuff I've written)
its_virgil is offline   Reply With Quote Top
Old 02-27-2017, 08:07 PM   #6 (permalink)
Flush1974's Avatar
Photos: 38
Default
Don
Don,
Thanks for the reply. I'm not sure what you mean by the double triple or quad thread start. The threads are from a kit and most kits are triple start. The first pen like this I finished had triple threads and even though the grain didn't align everything was round. Now every cigar pen I complete is only round when I glue the tubes in and screw it together.
Old 02-27-2017, 08:07 PM   #7 (permalink)
magpens's Avatar
Photos: 41
Default
As I understand it, you use the Robert Larson to find the centers to drill for the tubes after you have rounded the blanks.
That's OK if the rounded blanks have not been turned down to size.
I would leave them larger than desired, do the drilling, glue the tubes in, trim the excess end wood to the brass tube ends, and then mount the blanks between centers for the turning down to size.
On my lathe, I put a cone in the headstock and a live center in the tailstock and put the drilled (and tubed) blank between the cone and the live center.
That process ensures that your turned blank is centered on your brass tubes.
I would glue the "ashes" on as the last step, or the last step before finishing.
I may not be completely understanding everything you wrote.
__________________
Mal
magpens is online now   Reply With Quote Top
Old 02-27-2017, 08:15 PM   #8 (permalink)
Flush1974's Avatar
Photos: 38
Default
I would leave them larger than desired, do the drilling, and then mount the blanks between centers for the turning down to size.
I actually use the Robert Larson twice. I use it to find the center of the square blank to ensure I'm turning it between centers. Then I turn it round, and part it with a parting tool. I again use the Robert Larson to find the center of the rounded parts to drill the holes.
I have tried to glue the tubes in and screw them together and turning it to final dimensions again on the lathe and still can't get it to always be round. I was starting to think maybe it's the slop in the drilling as indicated in the pictures. It looks to me that the tubes are not center once glued. Does this have anything to do with the parts not aligning round?
Old 02-27-2017, 08:40 PM   #9 (permalink)
magpens's Avatar
Photos: 41
Default
If you use the Robert Larson a second time after turning the blanks down to size, your "second centers" will never coincide with the "first centers".
You should do the turning down to size only after the actual centers have been unalterably defined, the holes have been drilled, and the tubes have been glued in.
I apologize if I am not fully understanding.
If you are using a collet or a 4-jaw chuck when you do the drilling of the already rounded blanks you should not have to mark the centers ... the collet or chuck will define the centers for you.
__________________
Mal
Old 02-27-2017, 09:18 PM   #10 (permalink)
Flush1974's Avatar
Photos: 38
Default
That would explain why I had so much instability yesterday when I tried again. I could tell something was off but I couldn't figure out why.
So I should measure center ONCE, turn to desired dimension and just collet it and drill. Right?
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
