Need some advice
justaccord
Colorado, USA.
Trying to make a barrel to thread onto a Lamy joy calligraphy pen section. Section measures 3/8 across top of threads.
Used 11/32 drill and 3/8-24 tap with proper holder. Hand tapped 3-4 times using entire tap. Section starts to thread well and then seizes.
What am I doing wrong?
Thanks.
justaccord
Colorado, USA.
Thanks Mike. i will try again (obviously brand new at this threading business).
What explains why the section threads on part way then binds?
Does anyone know what the section-barrel thread size/pitch is for Lamy?
Ed McDonnell
Melbourne, FL
If the Lamy section goes part way into the threads you cut and then binds, here are a couple things I would look at as possible problems:
1) maybe you didn't cut the threads deep enough. Especially if you are using a tapered tap.
2) maybe you got close on the pitch / count, but not close enough. Getting an imperial and metric thread gauge won't cost a lot and can save you a lot of headaches in figuring out what thread you are trying to duplicate. Eyeballing the threads against a ruler can get you close, but not always close enough.
I don't know what the thread on the Lamy is. Sorry.
Ed
duncsuss
Wilmington, MA
Did you turn down the outside of the barrel before you tapped the hole?
If so, maybe there was enough flex in the material to let it stretch a little as you tapped it. This has happened to me, I found the best approach was either to put the barrel into a collet chuck and tighten it up, or to drill and tap while there was still a lot of material around the hole.
79spitfire
Nevada
Lamy is a German company, I am 99% sure the threads are of a metric size, likely something like 9.8X1.0 or so. It is also a multi start, with 2 thread "tracks". I don't have a thread pitch gauge handy to check, it's at work. The joy uses the same size section as the Safari or Al-star.
justaccord
Colorado, USA.
Thanks to all of you. Very helpful responses.
79spitfire, I checked and indeed it is a double start. Will a single start tap work with that thread, or do I need a double tap for the inside (barrel) threads as well?
I do not yet have a gauge (one is coming shortly), so if you can measure the thread pitch and let me know I would greatly appreciate it.
Thanks again. The first thing I want to try is kitkess pens which use manufactred sections and nibs. I really like the way the lamy stub writes, and want to make a custom barrel for my first kitless pen. Since the cap snaps onto the section, it will be an easy project once the threadi g is straightened out.
Dave
justaccord
Colorado, USA.
Update
Just returned from a business trip-- my thread pitch gauge was delivered and best I can measure the thread is 9mm-0.75. (My thresd gauge (little machine shop) has .75 and 1.0 with nothing in between-- is that accurate enough?)
Anyone know where I can find a double tap in that size?
79spitfire
Nevada
9X.75mm is common enough, but double start isn't. If you really want to do a lot of these you might have to have a tap custom made. Tapco does it, but it isn't cheap!
