Texatdurango
Brian said.........I can tell you the the pitch is .5mm. The major diameter is .250".
I would recommend sending the housing itself to whichever company is making your tap.
This way, you take the responsibility of accurate specs off of yourself, and onto the company.........Justin
Something is ODD here! The thread pitch on the Jr Gent section is not .5mm, they are courser than that, closer to .75 pitch.
Brian, if you are reading this, Can you shed some light on this?
If the meister nib feed is .5mm then it can't be a "plug and play" or direct screw in replacement for the Jr Gent and other kits..... unless you just want to cross thread the feed and call it good!
Justin is not the only pen maker trying to find a reliable source for nibs/feeds for his custom creations. Finding a nib and feed for sale is one thing, finding the proper tap to make threads in a custom made pen section to accept that nib/feed is another story.
