How to make acme style threads for cap - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 02-08-2019, 06:25 PM   #1 (permalink)
Photos: 0
Default How to make acme style threads for cap
Hi All,
I am looking for basic instructions on how to make acme style threads on a metal lathe. Also I wonder what is the correct piece to use for the thread cutting...?
Here you can see attached a fine example of acme threads, I would love to get that same result as in the first pic where the black part seems to go all the way inside the barrel.
carandacher is offline   Reply With Quote Top
Old 02-08-2019, 08:46 PM   #2 (permalink)
Photos: 0
Default
There are numerous YouTube videos on single pointing both internal and external acme threads. You May need to go a little bit beyond that to figure out the relationships between pitch and thread depth, etc.
External thread tooling should be relatively inexpensive, but you may need to spend a bit more for internal tooling. at these small diameters.
Bill
bmachin is offline   Reply With Quote Top
Old 02-08-2019, 10:37 PM   #3 (permalink)
BRobbins629's Avatar
Photos: 49
Default
This would also work on a metal lathe putting the bit in the head stock.
http://content.penturners.org/librar..._threading.pdf
You could also grind internal and external bits and thread the normal way on a metal lathe. You would want a bit about .050 in width and cut at 10 threads per inch.
__________________
Bruce
BRobbins629 is offline   Reply With Quote Top
Advertisement
Old 02-09-2019, 12:30 AM   #4 (permalink)
More4dan's Avatar
Photos: 5
Default
With a metal lathe you could turn external threads on drill rod and make your own taps. Turning ID threads for small diameters is difficult. Iíve done this for normal threads and I assume it would work for ACME threads. If interested, let me know and I could walk you through the steps.
Danny
More4dan is offline   Reply With Quote Top
Old 02-09-2019, 01:26 AM   #5 (permalink)
Photos: 1
Default
jalbert seems to have mastered the process. Message him and see if he has a few tips he can share beyond what has been suggested so far.
Green and silver
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 02-11-2019, 10:05 AM   #6 (permalink)
jalbert's Avatar
Photos: 3
Default
Quote:
Green and silver
Those are actually square threads (no wall angle), not acme. I grind my own tools, so Iím not sure whatís commercially available. Besides taking a lighter depth of cut per pass, I find them no different to cut than 60 degree threads.
jalbert is offline   Reply With Quote Top
Old 02-11-2019, 10:35 AM   #7 (permalink)
More4dan's Avatar
Photos: 5
Default
Quote:
Green and silver
What are you using for your bit geometry for cutting your threading tool? I was thinking a cutoff tool but wasnít sure if it would have the necessary side clearance as it progressed along the thread.
Danny
Old 02-11-2019, 10:46 AM   #8 (permalink)
jalbert's Avatar
Photos: 3
Default
You would probably get the best results from grinding some sort of helix angle . No machinist am I, so I don’t have a good explanation of the specifics. I just trial and error it.
Old 02-11-2019, 10:54 AM   #9 (permalink)
Dalecamino's Avatar
Photos: 219
Default
I found this on youtube
https://www.youtube.com/watch?v=Ioi0mIVfvHA
__________________
Chuck Hutchings
Indianapolis, In.
You can see some pens at http:www.facebook.com/chuckspens
Dalecamino is offline   Reply With Quote Top
Old 02-11-2019, 01:39 PM   #10 (permalink)
Photos: 0
Default
If you're interested in single pointing a true acme threads you are going to need specialized tooling. Cheapest source is probably Ebay:
https://www.ebay.com/sch/i.html_from...+tool&_sacat=0
This link shows a couple of solid carbide 12 tpi acme tools that will fit inside a pen cap for around 35 bucks.
If you already have some sort of insertable toolholder you can probably find acme inserts that will fit it for the external threads.
Taps for the internal threads are fairly expensive. The ones at Victornet and McMaster will only work for through holes. I'm just making this up but it seems to me that the loads on something as thin as a pen cap would be dangerously high when tapping an an acme thread.
Single pointing a female thread isn't all that difficult. John Albert does it on every pen that he makes, and I've done it on many.
Another tooling source that is a lot more expensive but very good is Thinbit:
Threading and Chamfering Products
FWIW
Bill
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
