How to attach a clip to a silver pen? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 02-25-2019, 09:25 AM   #1 (permalink)
Photos: 0
Default How to attach a clip to a silver pen?
Any suggestions on how to attach a clip to a round sterling silver pen? Jewelry welding instruments are available for this project.
A link to a general guide to making and attaching clips would be also very welcome.
carandacher is offline   Reply With Quote Top
Old 02-25-2019, 11:28 AM   #2 (permalink)
Photos: 21
Default
Is this a pen that's already made or one being created?
McKenzie Penworks is offline   Reply With Quote Top
Old 02-27-2019, 07:10 AM   #3 (permalink)
Photos: 0
Default
Quote:
It's in the crafting process. I am interested about various methods on how the clip can be attached.
Advertisement
Old 03-15-2019, 08:50 AM   #4 (permalink)
Photos: 0
Default
Any suggestions on how one can screw the clip into the cap with a single screw and avoid rotation of the clip?
I am attaching here a few pics
Old 03-15-2019, 09:06 AM   #5 (permalink)
BSea's Avatar
Photos: 46
Default
You could solder a small pin or even just leave a solder boll just below the screw on the inside of the clip. Then create a small dimple that would accept the pin/solder ball. When screwed in, it should prevent the clip from rotating under normal use.
__________________
Bob
Central Arkansas IAP Chapter Member
BSea is offline   Reply With Quote Top
Old 03-15-2019, 10:13 AM   #6 (permalink)
More4dan's Avatar
Photos: 5
Drill a small hole off center from the main hole part way through the back of the clip and a matching one on the pen cap. Use a matching diameter brass pin to lock the clip in. Id probably glue it to the cap to keep the customer from loosing it when they remove the clip. If there is a screw someone will remove it especially if they are an Engineer.
Danny
More4dan is offline   Reply With Quote Top
Old 03-15-2019, 10:34 AM   #7 (permalink)
skiprat's Avatar
Photos: 227
Default
Another method could be to have the single screw and the hole through the cap non-round. File a flat on the screw and make a D shaped hole in the cap to suit.
There are hundreds of examples where this method is used. Old school car door locks.....metal cabinet locks....switches and knobs through fascia plates etc etc
__________________
www.skiprat-pens.com
skiprat is offline   Reply With Quote Top
Old 03-15-2019, 12:28 PM   #8 (permalink)
Photos: 0
Default
the pen is sterling silver.
The D screw might work, but how could I tighten it from the inside of the cap?
the dimple idea is also very good
Danny's idea is also great, perhaps easiest to make
Old 03-15-2019, 12:57 PM   #9 (permalink)
skiprat's Avatar
Photos: 227
Default
Put the nut on and tighten it inside the cap and then press your finial in.
You can even do it without a screw thread....
Have a D shaped fake screw that passes through the clip and then through the matching hole. Instead of an awkward nut to tighten, have a small hole through the fake screw and then insert a small tapered pin/wedge.
Where there is a will, there's a way.
__________________
Old Yesterday, 02:21 PM   #10 (permalink)
Photos: 0
Default
How about this method of attaching the clip, seems rather difficult to make. How would one go about attaching a pen clip like this on an ebonite or silver pen?
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
