H/F 7x10 metal lathe
OKLAHOMAN
Costa Rica
Just saw that the 7x10 is on sale for 499 and with the 20% discount code is $399.
Is this a good starter metal lathe, or should I just wait and get a 7x12?
nsfr1206
Gainesville, Alabama
10 seems to be a little short. When you put a bit in a drill chuck and have a blank in a chuck on the head stock there isn't any extra room.
randyrls
Harrisburg, PA 17112
Roy; This is a case where longer is better. See if you can find a 7x14". Metal lathes don't usually have bed extensions because the lead screw must be extended as well.
I believe Little Machine Shop has complete bed extensions, but it involves replacing the existing bed and lead screw with a new one and re-aligning the lathe.
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Roy if you already have a decent set up for drilling blanks on the lathe on your wood lathe. THen this lathe will work for making small parts. However I would recomend you wait and buy a 14in or longer lathe. No sense in buying something that you will outgrow quickly.
Kaspar
Ahead of the curve. Waaay ahead.
This is a good lathe and if you get screw machine drill bits it's got plenty of room.
Yup. And that's not the only reason to go with "stub" bits. It seems to me the closer / shorter you can position everything (esp. towards the headstock) the more accurate things will be, especially if the lathe is reasonably on. I have a 7 X14 but I plunked down for this set and I have not regretted it.
bluwolf
SW Florida
Kaspar makes a good point about the closer you can get to the headstock the more accurate it will be. That's why they make center drills and why you should always start a hole with one. They're very short and stiff and made for starting holes on center and without walking like longer bits can.
http://www.littlemachineshop.com/products/product_search.php?critFast=center+drills
The cone shaped hole that these center drills make grab the tip of your longer drill bit even if it's not quite straight and draw it on center. They're quite inexpensive for a set that will drill the materials most people here are using, like wood, acrylic, and aluminum.
And they're not just for use on the lathe. You can use them anywhere you're going to drill a hole, even in a handrill. For less than $6 everybody should have a set of these around.
Paul in OKC
Oklahoma City, OK, USA.
If you are not doing anything longer than a couple of inches, it will work. I had one for a while and did just fine.. But longer is easier to use. But then again, you've seen what I am used to! These are very tiny toys compared to them.
bluwolf
SW Florida
Paul, my 12x36 is a toy compared to what you're used to:rolleyes:
DozerMite
Banned
Roy...the 10" would be way to short. It's not actually even 10", more like 8".
I got the 12" delivered for less than the 10" is on sale. It was on sale, I used the 20%, and found a promo code in addition.
When I can afford one, I'm going for a full size gap bed. I know a guy that has a SB, something like a 14" x 48" or around that for $500. The only problem is it's 480v 3ph.
BKelley
Tucker, Georgia, 30084
I had a chance to get the HF 7 x 10 used but like new for $250 but turned it down in lieu of a Grizzly 7 x 12. Glad I did. Don't think you will go wrong to wait for a 7x12.
Ben
OKLAHOMAN
Costa Rica
Mike I've been in Pauls shop a number of times, most of the SMALL equipment there won't fit in my shop empty :biggrin:.
Woodlvr
Midvale, Ut,
Thanks Roy now I want to see Paul's shop:) I have been watching one of our tv stations free classifieds and Craigslist and I hardly ever find one closer to home.
altaciii
corpus christi, texas, USA.
Roy,
I've had my 7x10 hf metal lathe for almost 3yrs and enjoy working on it. At first it was a hastle to get used to the smaller size as compared to my wood lathe but let me tell you it will make some very nice pens. The lathe has been good and I've only had one minor adjustment. For the money, it works fine.
jedgerton
Austin, TX, USA.
Just a little known fact, the 7x10 is 4 inches shorter than the 7x12. Doesn't make saense but I think it's that strange metric system! Hold out for the 7x12.
John
RHossack
Liberty Lake, WA, USA.
I personally would pass on this as it really isn't what it seems to be.
While HF calls the 7x10 it doesn't have 10" of usable bed space.
While the lathes designated 7x12 is nearly 4" longer than the 7x10.
Due to the short bed the 7x10 can't drill into the end of a workpiece longer than about 4" if the diameter is greater than 3/4" and will not pass through the spindle.
