Good place to start for closed pen ?
Petricore
Austin, TX
Sorry for the newbie question. I've read articles in the past on closed ended pens and recessed clip pens. I'm really wanting to make a closed end/recessed clip fountain pen for myself, but am lacking the ability to find these articles so I can get cracking. Any help would be appreciated :)
-Linc
Dan_F
Spokane, WA, USA.
Linc---There is an article in the library on how to make a closed end mandrel, also a number of posts on alternative methods of making a mandrel. Or you can buy a closed end mandrel (kit specific) from Arizona Silhouette. Not sure what you mean by "recessed clip". Good luck.
Dan
IPD_Mrs
Zionsville, Indiana
Petricore
Austin, TX
Wow those are pricey, but I guess I can pass that along to my customer :)
Thanks for the links, they are fabulous. I definitely like the recessed clip better so you can completely close the cap instead of making a screw on finial.
redfishsc
North Charleston , SC
To MAKE a closed-end mandrel is really easy if you have a collet chuck that will hold 5/8" bar stock/dowel.
I use metal, like brass or aluminum. Some use wood, nothing wrong with that.
Chuck the material in the collet chuck, and turn down a tenon that is about 1.5-2" long and will make a snug fit for your tube. Use sandpaper as you get closer to the right size (sander belts are very, very tough and work great, I use 100 grit since I have a few damaged ones that I can scrap off).
IF PERCHANCE you get it too thin, never fear, for CA glue is here! Literally wipe on a few coats of CA finish (lol, don't micromesh it) to make it fatter for a more snug fit. Hose it with accelerator just to make sure it doesn't become a permanent part of your pen when you slide the blank onto it. You'll get a feel for what's right very quickly.
Don't worry about turning a bushing on it-- use your digital calipers to get the nib end right.
BTW, do ALL of your turning with the tailstock and live center engaged. Don't use a lot of tailstock force or you'll dimple your pen, but use the tail to keep it safe. When you are done shaping your pen, gently sheer scrape the butt end to the shape you want and remove any dimple. Sand, finish, and done. Piece of cake.
I love closed end pens. Simply sweet.
Petricore
Austin, TX
redfish - thanks for the details. I don't currently have a collet. Is that the preffered method of holding in the pin chuck or closed end mandrel ?
its_virgil
Wichita Falls, TX, USA.
Getting Russ' videos would be an excellent choice. He does a great job both showing and explaining the finer art of penturning. His attention to detail is great. In the meanwhile, I did a demo on closed end pens at the Utah Woodturning Symposium in May and all of the information I covered in the demo is included in some articles on closed end pens on my websie at http://www.RedRiverPens.com/articles and the articles show several ways to hold the pen blanks...some homemade and some commercially available. We look forward to seeing a picture of your creation.
Do a good turn dailhy!
Don
Petricore
Austin, TX
Thanks for all the info so far guys :) I'll definitely post once I get it down :)
I cannot believe I missed the symposium and pen turners group this year. I'm all of 10 minutes from where it went down (at MY school)....
its_virgil
Sorry you missed it. There were 8 penturning rotations at the symposium, 3 demos at the rendezvous, and 3 more at the Craft Supplies Super Wednesday sale. Watch for it next year.
Do a g ood turn daily!
Don
redfishsc
First off, I didn't know Russ had videos, or I would have likely pointed you in that direction.
As far as holding the pin chuck, you can use a drill chuck as long as it will hold 5/8" material--- if not, you'll need to downsize to 1/2" material (assuming you have a 1/2" drill chuck).
Make sure the drill chuck is properly seated in the MT2 before turning the pen.
BTW I turn my closed-end pens with speed at 3750 all the way (except sanding, that's 1200). I only remove the tailstock for the last few cuts on the butt end and for sanding.
