Gluing Acrylic to Wood
Tim
Tacoma, WA, USA.
Didn't see this subject elsewhere.
I am making segmented blanks which incorporate wood and acrylic. I have been using CA but it sets up pretty fast which can make alignments tricky. Has anyone experience with gluing these materials and what adhesives work the best?
Texatdurango
Show Low, Arizona
I've used 30 minute epoxy on quite a few acrylic/wood/truestone segments and no failures or complaints from customers yet. I've even mixed Pearl-ex powder with the epoxy to provide some interesting colored glue lines.
nightowl
Lexington, Virginia, USA.
I have used Gorilla glue on one of my segmented blanks. It worked great except that you have to scrape / sand the excess foam off of the blank after it dries. I have also used medum CA. It does not set up as quick.
RussFairfield
Passed Away 2011
Post Falls, Idaho.
I use a "Medium" CA glue. Most of the time I put the glue on the wood and the accelerator on the plastic because it works better than the other way around, and I have a few seconds to aligh the pieces.
If I need more time, I omit the accelerator and have over a minute to get it right, but have to make sure there is no accelerator present.
