Glue for ebonite
magpens
Canada
What did you use on your Wedge Pen that you posted today ?
I have never used ebonite yet.
TonyL
Georgia
I don't know the best, but I have had zero failures quick curing epoxy.
  • Like
Reactions: JLL
Best glue. I do not think there is one. Ebonite is a rubber based material. So my guess would be an epoxy but not one of those quick hardening epoxies. I would choose something like System III T88 or if you want instant glue Loctite 480 ( but it is black in color)
If you are gluing ebonite to ebonite it would probably be beneficial if you used a tenon system if possible to give more stability to the glue joint. Good luck.
  • Like
Reactions: JLL
JLL
Wales uk
Its not glued in yet Mal - ebonite is a great material to use it does hold shape /detail really well but does smell when turning.
Hendu3270
Pearland, Texas
When I create stem bands on my pipe stems (which are ebonite) I use two part epoxy. I believe it has a set time of maybe 5 minutes. It works well for me.
  • Like
Reactions: JLL
