Drilling with accuracy on a wood lathe - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 05-16-2014, 10:30 PM   #1 (permalink)
Photos: 0
Default Drilling with accuracy on a wood lathe
I would like to know how some of you drill (accurately) on a wood lathe. I use a drill chuck that fits into the MT2 on the tail stock. As soon as I loosen the quill to advance the drill, it chatters and wobbles all over the place, even if I am holding it at the base of the chuck to steady it.
The other alternative I have tried is to keep the quill locked, and just manually push the tail stock in slowly. But it's the same issue... once the tail stock is loosened, there is too much play and the end of the drill dances back and forth making a very inaccurate hole.
I use a 60 degree center starter before I drill. But I am not happy with these results. This kind of wobble is not nearly precise enough for the close tolerances needed to make a kitless pen. Is there a better way to secure a drill, than using this MT chuck?
penfetish is offline   Reply With Quote Top
Old 05-16-2014, 10:37 PM   #2 (permalink)
Photos: 0
Default
What has worked for me is to lock the tailstock with the bit real close to the blank.
Then tighten the quill down and then back it off just slightly to allow the handwheel to advance the bit. You need to go real slow here so the bit is barely digging in. Once the bit has advanced about 3/16" you can loosen the quill more and advance faster.
I also pre-start the holes either with a center bit or with a round flat tool. It is important that there is no material in the center of the started hole to allow the end of the bit to go off center.
__________________
Dale Allen is offline   Reply With Quote Top
Old 05-16-2014, 10:54 PM   #3 (permalink)
BSea's Avatar
Photos: 40
Default
That's about what I do. But what do you mean by starting the hole with a round flat tool?
About the only other thing I do when I really want a good true hole is to drill a pilot hole about 1/16" smaller than the final hole.
__________________
Bob
Central Arkansas IAP Chapter Member
BSea is offline   Reply With Quote Top
Advertisement
Old 05-16-2014, 10:59 PM   #4 (permalink)
Photos: 0
Default
Thanks Dale. I think part of the problem is the length of the drill + the length of the chuck holding the drill, makes for a very long extension and the vibration gets magnified. I have tried your method, but perhaps I loosened the quill too much at first. It seems the taper in the tail stock has a lot of play in it as soon as the quill is loosened.
Old 05-16-2014, 11:28 PM   #5 (permalink)
its_virgil's Avatar
Photos: 74
Default
I put the blank between centers and turn it round then cut into the needed two (or one) parts. i hold the blank with my collet chuck then drill. I make a lot of one piece slim lines and drill from both ends with a standard size bit and the two holes meet dead on. Drilling on the lathe is a very accurate way to drill. I also use a center drill.
Do a good turn daily!
Don
__________________
Don Ward aka its_virgil
Wichita Falls, Texas
www.RedRiverPens.com
www.RedRiverPens.com/articles.htm (pen stuff I've written)
its_virgil is online now   Reply With Quote Top
Old 05-16-2014, 11:49 PM   #6 (permalink)
Laurenr's Avatar
Photos: 96
Default
This issue has driven me crazy for years. So crazy that I finally bought a metal lathe. With the metal lathe I can drill with complete accuracy. I suggest that if accuracy is as important to you as it is to me, you might want to bite the bullet and purchase a metal lathe.
While using a wood lathe, I found that using a collet chuck helps, but only if you have the blank very evenly rounded. Center drills, pilot holes, slow speed, sharpened bits, and reamers, will help also. A center drill will also help with drifting when using a drill press.
The bottom line is that wood lathes are just not made for the kind of accuracy needed for kitless pen making. Yes, it can be done, much better by some than others, (and no doubt we'll hear from a few directly after I post this), but if you are asking this question, I'm guessing you won't be happy until you have a metal lathe. IMHO.
Lauren
__________________
Life's heaviest burden is having nothing to carry.
Laurenr is offline   Reply With Quote Top
Old 05-17-2014, 12:16 AM   #7 (permalink)
johncrane's Avatar
Photos: 190
Default
I also do what Don suggest.
__________________
SUCH IS LIFE. Down Under.
johncrane is offline   Reply With Quote Top
Old 05-17-2014, 01:05 AM   #8 (permalink)
Photos: 0
Default
Quote:
Lauren
I have been thinking about this very same thing, and spent the last hour looking at metal lathes. It's a whole other animal! But I agree, the lack of precision is driving me crazy, too.
I have spent days making fountain pen sections, and every one of them comes out differently - using the same tools - because there is too much play in the tail stock when drilling. It affects the threads when tapping, it enlarges the 1/4" bore where the converter fits in, and where the nib housing meets - the opening is oval. Measure, measure, measure, drill ... start over.
I suspect this what they call chasing the dragon.
Old 05-17-2014, 08:24 AM   #9 (permalink)
duncsuss's Avatar
Photos: 1
Default
You haven't said what brand or model lathe you own, but there's a possibility you could improve things by fixing your tailstock so it doesn't have nearly so much play.
For example, you could add shims to the guide plate under the tailstock (the one that's supposed to keep it perfectly centered and aligned along the axis). Then at least you'd have it starting out pointing the right direction.
duncsuss is offline   Reply With Quote Top
Old 05-17-2014, 08:32 AM   #10 (permalink)
Dan Masshardt's Avatar
Photos: 0
Default
The lathe question is a good one.
What are you using to hold the blank?
Except for kitness style stuff, I don't see why extreme accuracy is so vital.
I get good accuracy. With my nova chuck.
And epoxy always makes up any difference. For gluing tubes in that is.
Dan Masshardt is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
drilling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
