drill bit/tap and die chart??
RAdams
Banned
Is there a chart or something that tells a big dummy like me what size drill bit to use for what size tap? and what diameter material for the matching die? thanks for any help!!
Paul in OKC
Oklahoma City, OK, USA.
That looks pretty complete. Should be able to google a chart and find one as well, but why now! (see above =8^) ). As for material diameter for the die, your thread diameter is what the od should be, maybe a couple of thou under if anything. IE a 3/8-16 thread for example, 5/16 drill for the tap. 3/8 diameter for the die.
randyrls
Harrisburg, PA 17112
Hi Ron; Try this chart. Includes both Imperial and metric in all standard threads.
Take a gander around this site. LittleMachineShop has just about everything for the hobbyist metalworker. Very good information there!
http://www.littlemachineshop.com/Reference/TapDrillSizes.pdf
RAdams
Banned
good grief... I am doing something WAAAY wrong. Itried to use the 3/8 die on a piece of PR that was just barely under 3/8. It wouldnt even think about starting. I chamfered the end and still nothing. I need lots of practice or better tools or something...
ldb2000
Laurence Harbor, NJ, USA.
Ron , PR is a bear to thread without breaking . The softer acrylics like madreperlato from Ed and Dawn at exoticblanks.com are much better because they are not quite as brittle . To thread PR you are better off making a longer tenon and tapering it to help start the die then take very small cuts (1/4 turn or less) then turn the extra length off . Tapping isn't as bad but you should get all your threads cut while the blank is still full diameter then turn to the correct size .
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
You don't need a chart ( though it is a nice quick reference )
Metric; simply subtract the small number from the big number = drill size
Standard; Use the magic number 0.9742
0.9742 divide Pitch = 'x'
Decimal Tap size subtract 'x' = drill size ( in decimal )
RAdams
Banned
TOTALLY makes sense!:confused:
I could always subdivide the co-radient by the infractional quadrant, and then account for drag and wind resistance.
I gradieated from the tenf grade boss. I am lucky to be able to read the chart.
