Decal finish question.
Marnat3
St Paul Minnesota
Is it a must using CA before and after to apply a decal?
Can I use Huts CC? I really like the feel of the CC finish on the finished pen.
Making a set of pens for our wrestling teams silent auction and a couple to present to the coaches as thanks.
England
Even though I have not tried other methods, I still believe it is the best way to seal properly the decal and avoid your fingers to detect the decal edges.
akingkubo
Texas
I am also practicing to add decal this weekend.
I tried to put a name decal (black print) today on a cocobolo before I CA. After. 4 coats I noticed the background part of the letters (which is clear) turned gray on the cocobolo. I wind up having to sand it off. Do you think maybe I should have put a few CA first then add the decal like Patrick?
Maria
Marnat3
St Paul Minnesota
You need a base for the decal to lay on. From what I have learned here, 2 coats thin CA should be good. Apply decal, blot and let dry, and add 2 or 3 coats Med CA.
wouldentu2?
Oak Creek WI
Apply CA to the pen, polish it to a high shine and apply the decal followed with how much CA it takes to get a smooth finish. The first coats of CA prevent the finish under the decal from having a matte appearance.
